Car chokes when starting any suggestions?
Old Apr 18, 2003 | 08:36 PM
Mike813's Avatar
Default Car chokes when starting any suggestions?
recently the car has a bad start,
when i turn the key, it chokes for a few seconds before it starts,,,
back then it use to start on the first turn,
anyone know what might be wrong??
or what i might need to change or check up on?
thanks..
Old Apr 21, 2003 | 06:09 AM
Mike813's Avatar
Default Re: Car chokes when starting any suggestions? (Mike813)
Old Apr 21, 2003 | 10:20 AM
dclub01's Avatar
Could be a few things...
1. could be that ur car isn't getting enough air?
2. could be that ur car isn't getting enough gas?
3. could be that ur car has bad spark plugs?
4. could be... there is more, but check these out first...
Old Apr 21, 2003 | 06:16 PM
Mike813's Avatar
Default Re: Car chokes when starting any suggestions? (dclub01)
1...i checked my throttle body and cleaned it its doing ok
2...gas part i dont know how to check that? do i need to change the filter u think?
3...spark plugs was just changed less than 2k miles.
4...?
it only does this once in a blue moon, not always...so u think it might be my gas filter? i have never changed that before since i got the car at 57k miles.. im way over 100k now...
thanks for the reply..
Old Apr 22, 2003 | 09:41 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike813 &raquo;</TD></TR><TR><TD CLASS="quote">...spark plugs was just changed less than 2k miles...</TD></TR></TABLE>
How about distributor cap & rotor, & spark plug wires? How old are they?
Old Apr 22, 2003 | 11:19 AM
Mike813's Avatar
Default Re: Car chokes when starting any suggestions? (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
How about distributor cap & rotor, & spark plug wires? How old are they?</TD></TR></TABLE>
i changed them the same time i changed my spark plugs, had a tune up,
so the only thing i think that it might be is the gas filter?? i think...
Old Apr 22, 2003 | 02:52 PM
RotaryBzzz's Avatar
fuel filter on 94+ is a bitch to change. Many ppl just don't want to do it unless the master brake cylinder is out. Try changing that if your over 80k miles...(technically the change interval is 30k)
Old Apr 23, 2003 | 03:34 AM
Mike813's Avatar
Default Re: Car chokes when starting any suggestions? (RotaryBzzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzz &raquo;</TD></TR><TR><TD CLASS="quote">fuel filter on 94+ is a bitch to change. Many ppl just don't want to do it unless the master brake cylinder is out. Try changing that if your over 80k miles...(technically the change interval is 30k)</TD></TR></TABLE>
well lets say, ever since i got the car i never changed the filter, nor do i know if the last owner did... so im assuming its been damn long since the fuel filters been changed ,,, how much you think local shops would do this for??
editingideas
Jul 25, 2018 11:33 PM
danny_ha
16
Jan 13, 2008 07:42 PM
leekor12
Apr 20, 2007 08:45 PM
greddy13
Apr 10, 2006 06:54 PM
