I think I screwed up my wheel bearing - come point and laugh!
Old Apr 18, 2003 | 06:52 PM
maharashii's Avatar
Default I think I screwed up my wheel bearing - come point and laugh!
While changing my tire, I broke a wheel stud, so I looked for my repair manual, but couldn't find it. I figured I'd tackle the project cold.
I took off the caliber, removed the disk, and found that you can't get the wheel studs on without removing the hub.
My neighbor, who is a bit more savvy than I, suggested that I remove the hub by spinning the really big nut (1" or 1 1/4") counter-clockwise.
Well, I did that, and I managed to spin it.
It didn't feel right, so I came in here to find out how to do it right.
When I found out I needed to either cut the shield and trim the studs, or remove the hub with a special tool, I decided to call it quits and let a shop handle it. It's too cold outside for this ****.
Anyhow, I put it all back together and tried to go for a ride, and now I am getting this hideous grinding noise from the affected wheel.
The sound is not affected by engine speed or brakes. It increases in volume and pitch with the velocity of the vehicle.
I'm guessing that it's the wheel bearing. I probably torqued the hell out of it when I spun that big nut.
Sound right? Just how dumb was that ...
Old Apr 18, 2003 | 07:36 PM
sporkcrx's Avatar
Default Re: I think I screwed up my wheel bearing - come point and laugh! (maharashii)
Well if you were spinning it counter clockwise you were taking it off...btw it's called the axle nut. I would tighten it back on before you go driving.
Old Apr 18, 2003 | 07:50 PM
FourthGenHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maharashii &raquo;</TD></TR><TR><TD CLASS="quote">
It's Caliper, not Caliber.
Also even with the axel nut off you need a press to push out the hub anyway, I don't think you can do it with hand tools that I know of.
Old Apr 18, 2003 | 07:53 PM
Shawn C's Avatar
In The Garage
did you put the wheel on and roll the car around with the brakes off? or an axle out (for some reason?)
Old Apr 18, 2003 | 08:59 PM
maharashii's Avatar
Default Re: (22lbGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">It's Caliper, not Caliber.</TD></TR></TABLE>
thanks for the spellcheck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R &raquo;</TD></TR><TR><TD CLASS="quote">did you put the wheel on and roll the car around with the brakes off? or an axle out (for some reason?)</TD></TR></TABLE>
nope. didn't touch the axle. vehicle was jacked up at all times.
ok, so maybe I need to look up a diagram.
in any event, it seems unlikely that I damaged the wheel bearing or axle.
When I turned the axle nut, it didn't feel like the nut was turning smoothly. It just didn't seem right. It was like the axle itself was turning, but I'll have to verify that. I'll also make sure the axle nut is back tightly.
Anything else?
Old Apr 18, 2003 | 09:07 PM
USDM 4G VTEC's Avatar
to complicated.... to long to write...
all i can say... seriously (im not jokin and dont get offended) but u dont know what u doing or what u have to do.... let someone who has tools, knoledge and experience handle that job before something else gets broken or gets mroe expensive
Old Apr 18, 2003 | 11:39 PM
ScottEK's Avatar
Default Re: I think I screwed up my wheel bearing - come point and laugh! (USDM 4G VTEC)
Just so you know I highly doubt you over torqued the nut in question, even though it has absolutly nothing to do with the sound you are hearing that bolt is supposed to be torqued to 130ft/lbs.
Old Apr 19, 2003 | 09:40 AM
maharashii's Avatar
Well ... I did not break the axle nut loose.
When it turned, I must have turned the entire axle. My best uneducated guess is that I damaged the spindle or wheel bearing.
Next purchase will have to be a service manual...
For now, it is at the shop for more qualified repairs.
Old Apr 19, 2003 | 12:48 PM
rioninja's Avatar
make sure its not just the dust shield rubbing on the rotor.
Old Apr 19, 2003 | 02:31 PM
FR-MOB: ThE bEe GuY's Avatar
Before you go buy ANYTHING else, just take it to a shop n let them find out exactly whats wrong with it before you buy a whole lotta **** you dont need.
Old Apr 19, 2003 | 03:04 PM
ScottEK's Avatar
Default Re: I think I screwed up my wheel bearing - come point and laugh! (ThE bEe GuY)
Get someone to look at it, there is no way you turned the entire axle if the wheel did not move. You would have to rip all the splines apart Mr. Muscles.
Old Apr 20, 2003 | 12:54 AM
maharashii's Avatar
Default Re: I think I screwed up my wheel bearing - come point and laugh! (rioninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">make sure its not just the dust shield rubbing on the rotor. </TD></TR></TABLE>
good thought - I didn't manipulate the dust shield at all, but here's to hoping it's a simple fix
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the bee guy &raquo;</TD></TR><TR><TD CLASS="quote">Before you go buy ANYTHING else, just take it to a shop n let them find out exactly whats wrong with it before you buy a whole lotta **** you dont need.</TD></TR></TABLE>
done - but just for the record, all I have purchased is the replacement wheel stud and lug nut, so I'm ok on that account.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">You would have to rip all the splines apart Mr. Muscles.</TD></TR></TABLE>
heh, well ... I have been working out lately ...
We'll see what happened when they replace the wheel stud
thanks,
maharashii
Old Apr 20, 2003 | 01:26 AM
SiR Kid's Avatar
New User
My vote's on the dust shield... those things are within 5 mm stock, any movement and they'll rub and make horrible noises.
Old Apr 24, 2003 | 09:46 AM
maharashii's Avatar
Default Re: I think I screwed up my wheel bearing - come point and laugh! (SiR Kid)
so autozone gave me the wrong wheel stud. very annoying.
in any event, the shop fixed the broken stud. The grinding noise was indeed the dust shield. no biggie there.
Old Apr 24, 2003 | 10:37 AM
baytall79's Avatar
Thats good you found your problem and it wasn't as bad as you thought. In the future ( hopefully far future), if you want your wheel bearing just jack the front of your car up just to the tires off the ground and wiggle your whole wheel. There shouldn't be any play at all, if there is then your bearing's shot. With have a 10+ year old car it's just something most of us come across eventually
John 07
Jun 26, 2008 11:33 AM
YoungKadafi
Suspension & Brakes
Mar 10, 2007 05:06 PM
JDM_SOHC
Nov 7, 2005 06:37 PM
Pompiuses
Sep 12, 2005 06:57 AM
turbob16ef
Suspension & Brakes
Sep 3, 2005 12:16 PM
