oil pan gasket, tightening?
Old Apr 18, 2003 | 05:04 PM
r7's Avatar
r7
Default oil pan gasket, tightening?
which sequence should i tighten the nuts/bolts on a bseries oil pan?
also, the oil pan gasket is a rubber one, do you have to use a gasket compound still?
i saw a diagram on here somewhere before, but can't find it now.
Old Apr 18, 2003 | 05:31 PM
b19coupe's Avatar
Default Re: oil pan gasket, tightening? (r7)
Put the gasket on dry, Honda does. Tightening sequence is not precise, as say cylinder head tightening, just do like a rotating X-pattern. Do not overtighten the oil pan, it will leak.
Old Apr 19, 2003 | 12:16 PM
r7's Avatar
r7
Default Re: oil pan gasket, tightening? (b19coupe)
what should i torque it to?
Old Apr 19, 2003 | 12:29 PM
b19coupe's Avatar
9 ft-lbs.
phelpsj2
Mar 9, 2010 12:16 PM
miro_gt
Jun 24, 2007 08:02 AM
StreetRacinThug
Dec 21, 2006 08:44 AM
deconstruct
Jun 18, 2004 01:00 PM
yellowbulbs
Jul 17, 2001 01:12 PM
