top speed ls integra???
Old Apr 18, 2003 | 12:32 PM
dohc-nyne's Avatar
Default top speed ls integra???
whats the highest u have topped out with non chipped ecu ls integra......
99 ls integra obd2 no chip i/h/e clutch flywheel.....140 mph top
Old Apr 18, 2003 | 12:35 PM
nek0's Avatar
Default Re: top speed ls integra??? (dohc-nyne)
93 4-dr ls i/e @ 125
Old Apr 18, 2003 | 12:38 PM
IntegCutie82's Avatar
145 and it wouldn't go faster.
Old Apr 18, 2003 | 01:14 PM
CNSK's Avatar
Default Re: top speed ls integra??? (IntegCutie82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegCutie82 &raquo;</TD></TR><TR><TD CLASS="quote">145 and it wouldn't go faster. </TD></TR></TABLE>
are you serious? 145 on LS? i have a 95 teg gsr and when i hit bout 125-130 seems like its stalling hard and my rpm/mph just pretty much stays at a spot. i dont know, maybe i didnt go far enough or maybe i should try a little downhill more but getting 145 seems pretty hard for me even trying to get 135mph. i dont know???
interesting...145 on ls and my gsr 130?
Old Apr 18, 2003 | 01:20 PM
marltonteg's Avatar
Default Re: top speed ls integra??? (DrMartin)
careful with all this...yeah i race...but 145 mph is not healthy...
Old Apr 18, 2003 | 01:23 PM
FORCED FED TEG's Avatar
New User
Little under 140 with I/H/E took forever to get up to speed.
Buried the needle at 150 with turbo, got up to speed in no time at all.
I don't recommend anyone doing this. I was just curious of what the car could do. And you know the saying curiosity killed the cat, I guess I got lucky.
Old Apr 18, 2003 | 01:29 PM
riceball777's Avatar
my top speed is 115 or 120 because of the speed limiter. cheep *** jdm ecu
Old Apr 18, 2003 | 02:22 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
Default Re: top speed ls integra??? (riceball777)
Ive been right around 135
Old Apr 18, 2003 | 04:08 PM
95 integra's Avatar
Default Re: top speed ls integra??? (integra707)
Lets also not forget that the speedo and tach are over-calibrated so its going to be less then what the tach reads. and if necessary I will post a pic of a friends that his tach shows him sitting at 7600 and his VAFC shows him sitting at right over 7100(digital, more precise...truthful). Therefore take 5-10MPH off what your tach was showing.
Old Apr 18, 2003 | 04:10 PM
Danger's Avatar
Default Re: top speed ls integra??? (95 integra)
my old 94 rs went up to 139.5ish mph , wouldnt go to 140
Old Apr 18, 2003 | 04:31 PM
PHAT-INTEGRA's Avatar
Default Re: top speed ls integra??? (JonnyDanger)
1999 GS stock at the time. I Got the car up to 136MPH. Would of gone faster but there were a cop in front of me. If I did got busted I would been in VA jail for racing my freind Delso in a 55MPH Zone
Old Apr 18, 2003 | 04:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrMartin &raquo;</TD></TR><TR><TD CLASS="quote">
interesting...145 on ls and my gsr 130?</TD></TR></TABLE>
GSR and Type-R are known for low end the LS is known for high end
Old Apr 18, 2003 | 04:38 PM
95 integra's Avatar
Default Re: top speed ls integra??? (PHAT-INTEGRA)
A LS known for top-end? WTF have you been smoking.
Old Apr 18, 2003 | 04:39 PM
UnCaNnYChInO's Avatar
i got to 115 and could of still gone faster
Old Apr 18, 2003 | 05:05 PM
usdmcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHAT-INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">
Yea...ls are know for low end...gsr and type r high end...vtec man
Old Apr 18, 2003 | 05:25 PM
TegSE's Avatar
132 on speedometer. Felt fine. Only mod was springs. 96 SE coupe
Old Apr 18, 2003 | 05:46 PM
Default Re: top speed ls integra??? (TegSE)
I always get them reverse some how.
Old Apr 18, 2003 | 06:45 PM
b00sted4dr's Avatar
135, but after 125 it takes a while to get up to 135.
Old Apr 18, 2003 | 06:55 PM
Smoochy's Avatar
Default Re: top speed ls integra??? (96Ls4dr)
130 in reverse! thats one fast GSR
Old Apr 18, 2003 | 07:45 PM
92lsr's Avatar
Default Re: top speed ls integra??? (Smoochy)
92 ls with i/h/e jg 301 cams tbody ect , 145 mph at 3 am in the morning 149 going down a slight hill , i had gsr rims on my car 15 inch (com[pared to 14 inch stock )i know the tachs are off a little so i would say 138-142 actual speed , the car gets up to 120 pretty easy , but after 120 MPH the car makes alot of weird noises and wind noises (KIDS DONT TRY THIS AT HOME )
now with my car with a b18c in with b16 tranny the highest i got it up to was 135 and my rpms was at 7800 , i havent went past 100 mph in a long time , pretty much anything past 100 MPH is a quick trip to go to jail 2 points on your driving record and your isurance will sky rocket , be careful out there everybody
Old Apr 18, 2003 | 08:01 PM
AWDxBOOST's Avatar
Default Re: top speed ls integra??? (92lsr)
damn...once i get to 100 in my car, it will barely pull at all. Im not sure how fast it can go
Old Apr 18, 2003 | 09:41 PM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHAT-INTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">I always get them reverse some how.</TD></TR></TABLE>
sure man, vtec engage 4400+5800 but no high end??????
LS=no vtec but strong high end???
Old Apr 18, 2003 | 09:53 PM
X2BOARD's Avatar
Don't know what he meant... but the LS gearing is good for top end.
I couldn't pass 125 or so with my 4Dr LS all motor, I/E, pulleys.
I buried the needle (140+) at 12 psi and wouldn't do it again... scary.
X2
Old Apr 18, 2003 | 09:59 PM
93solsigsr's Avatar
my friend has a pretty built 00 Si / type r tranny and he hit around 149-155
Old Apr 19, 2003 | 12:47 AM
Bman's Avatar
Default Re: top speed ls integra??? (93solsigsr)
Hit about 135 in a gsr with only intake on it. It was kind of scary, but I think I could of gone a faster. Vtech's secondary souds hella cool in fifth gear. Hauls *** after hitting the secondaries. I don't think I'll be doing that again in a long time though.
