CEL Code Error, 1 Blink. Oxygen Content
91 crx si with pm6 ecu and obd0 dizzy, si exhaust manifold, Z6 intake manifold, V-afc i get that cel code...perhaps running to rich? to lean? i know i need an A/F Guage but why would this code pop up?
you were probably running a bit rich and broke your O2 sensor. get you car tuned then check it out if you'll get the same code before you replace your O2 sensor and that should take care of your problem.
When you run a A/F guage it takes like .2 vlts to run the gauge. your ecu expects like .9 vlts or somethig. dont quote me on this, but in shirt the A/F guage takes volts away from the 02.
Good Luck
Blaze
Good Luck
Blaze
jbiel
11
Jan 11, 2009 06:27 AM
ridin98civic
Jun 21, 2007 07:47 PM
