shouldn't my car be faster?
i dont know what i would dyno,but i was running on nitto dragradials that are almost trashed.iwas getting the worst wheelhop i've ever experienced.
THIS IS EXACTLY AS THE SLIP GOES last wed4/16/03@san antonio raceway
reaction--0.6722
60ft-------2.2424
330ft------6.0234
1/8et------9.1477
1/8mph---78.68
1000et----11.8152
1000mph-NONE
1/4et------14.1018
1/4mph---98.59
reaction--0.6722
60ft-------2.2424
330ft------6.0234
1/8et------9.1477
1/8mph---78.68
1000et----11.8152
1000mph-NONE
1/4et------14.1018
1/4mph---98.59
That 60' sucks for having drag radials. My old CRX could pull 2.24 60's on crappy as dunlop tires. Work on the launch and get the wheelhop under control and you'll have a 13 second car easily. I imagine you should be pulling 1.9-2.0 60's.
ya you gotta practice on them launches. but hey everything takes practice. let us know how it goes next time you go. and ya you should be a faster.
IMO ur 60 foot are killin u
work on the launch.....
be i ran a 15.7 when i let the car go @ around 4k rpms and had a 2.6 60'
i ran a 15.4 when i let the car go @ 3k rpms and i had a 2.3 60'
i was talking to my nieghbor today and he said he normally runs consistant 11.68s(99ws6T/A) but due to the weather he was running 12.28s SO with that said shouldn't i be running atleast 13.60s then with practice i would be running faster?
Yes you should be running a bit faster, 4-1 header with 2 1/2' collector and exhaust would help the bottleneck, you didn't specify the size of your exhaust, but with that set-up you should def. be running 2 1/2"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx »</TD></TR><TR><TD CLASS="quote">
reaction--0.6722
60ft-------2.2424
330ft------6.0234
1/8et------9.1477
1/8mph---78.68
1000et----11.8152
1000mph-NONE
1/4et------14.1018
1/4mph---98.59</TD></TR></TABLE>
Your 60 ft. could be better, but you should still be running a faster 1/8 time with that 60 ft. You should still have run about 8.8 at 80+mph. Maybe you need to shift faster or something. Your 1/8 speed is too low. I ran 9.4 @ 77mph in a heavy *** 00 Civic Si with a 2.1 60 ft. Car only had i/h/e, VAFC and some nice suspension mods and the back seats removed. Work on that 1/8 time and speed, and try to get that 60 ft. down to at least 2.0 and you should easily be running 13s. Maybe your Jamex suspension is too soft and causing your launch to be crappy.
reaction--0.6722
60ft-------2.2424
330ft------6.0234
1/8et------9.1477
1/8mph---78.68
1000et----11.8152
1000mph-NONE
1/4et------14.1018
boosted91crx
Apr 8, 2013 08:08 PM
mike93boost
10
Feb 3, 2006 01:10 AM
i run 15.2 with b16a
