FS: Turbo Parts
Charge pipe w/BOV
Upper charge pipe, made for my 96 Civic w/LS engine, probably fits LS tegs also. Mild steel, 2.5" mig welded. Has TurboXS Type S BOV flange and INCLUDES polished TurboXS BOV. Good to approx 15 PSI I think. You're going to want to sand and paint the pipe, I used it temporarily while I was having one done in aluminum, so I didn't bother painting it. I can also supply you with the rest of the charge piping, silicone and good clamps, you'd just need to make if worth with your intercooler.
$100 OBO
Garret T3/T04B turbo
Has turbonetics housings, not sure of the trim, can measure for you or give whatever info you need. *Might* need a rebuild. Car (before wreck) gave a little puff of oil smoke every few days, so the seals might be going out. Comp housing is ground smooth, ready for polishing. Made 206hp/184tq on my SOHC at 9 PSI.
$250 OBO
Walbro255lph in tank fuel pump
Used for about a year.
$60 OBO
STR Titanium Fuel Rail
Used for two weeks...for B series. Includes STR fittings for use with stock lines, unopened, and has Earl's -6 flare fittings on both ends
$90 OBO (don't forget it includes the Earl's fittings).
HKS Type 1 US Spec Turbo Timer
Looks dirty but it's in perfect shape. Same as HKS Type 1 but readouts are in MPH instead of KPH, etc. Includes heavy gauge wire that was used to install in my Civic.
Asking $90 OBO
Modified by Hatchblack at 10:11 AM 4/19/2003
$100 OBO
$250 OBO
$60 OBO
Asking $90 OBO
You can see the comp in the pic above. I can take a better pic of it later if you'd like.
EDIT:
Just found another recent pic showing the turbo:
EDIT:
b20turbojason
Jun 9, 2005 06:12 AM
integraautox
May 25, 2003 09:18 PM
