Action clutch !! noise driving me nuts!!!
Old Apr 18, 2003 | 05:54 AM
swlabhot's Avatar
Default Action clutch !! noise driving me nuts!!!
Anyone using 2md or any other Action, experiencing the metal rubbing/grinding noise at certain positions on the clutch pedal when moving at low speeds or start-stop traffic?
This screetching noise quite loud and is driving me nuts!!
How can I remedy this problem?
Old Apr 18, 2003 | 06:54 AM
justinCO's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (swlabhot)
You know I've been meaning to ask the same question. I have a 2md also, it makes a pretty loud squeak sometimes when I shift from 1st to 2nd. It seems to only happen when I slip the clutch a little more than normal and also seems to happen only between 1st and 2nd gear. It is annoying, I'm paranoid that something is wrong, hehe. But it just sounds like clutch disk material squeaking on the flywheel during engagement. I don't get any grinding noise though, the clutch is real grabby when starting from first. That will sometimes make the car vibrate but that's about it.
Justin
Old Apr 18, 2003 | 07:14 AM
94dxt's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (justinCO)
it did that on mine @ first. You need to learn how to use it and fully break it in
Old Apr 18, 2003 | 09:41 AM
Farnsrocket's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (94dxt)
Yeah my 2MD will do that sometimes when I get sloppy shifting....but it's a great clutch!
Old Apr 18, 2003 | 10:10 AM
shadowdawn's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (Farnsrocket)
This only happen with the 2MD? I have a 2KS waiting to get swapped in, was wondering if the same problem happens with them...
Old Apr 18, 2003 | 10:42 AM
B18Flip's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (shadowdawn)
anyone else with the 2md???
Old Apr 18, 2003 | 10:47 AM
Sonny's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (B18Flip)
I have a 1MD with a sprung disk. The car should be on the road next week. I'll let you know.
Sonny
Old Apr 18, 2003 | 10:54 AM
FBP Si 2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadowdawn &raquo;</TD></TR><TR><TD CLASS="quote">This only happen with the 2MD? I have a 2KS waiting to get swapped in, was wondering if the same problem happens with them...</TD></TR></TABLE>
None that I know of.
r4adkshn1's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (Sonny)
no problem with the 2md on a friend's car. proper break in and he resurfaced his CM ~8 lb flywheel when he put in the 2md. I'm lookin to get another for a drag car.
if anyone can answer this:
will a 2md for a cable B16 trans work on 92 cable USDM B18A trans (YS1)? ive tried rocket, 2k-teg, and exospeed. anyone else with some help?
Old Apr 18, 2003 | 01:21 PM
B18Flip's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (r4adkshn1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r4adkshn1 &raquo;</TD></TR><TR><TD CLASS="quote">no problem with the 2md on a friend's car. proper break in and he resurfaced his CM ~8 lb flywheel when he put in the 2md. </TD></TR></TABLE>
cool i hope my refinnished itr flywheel/2md combo will do the job
Old Apr 18, 2003 | 01:40 PM
intekragsr's Avatar
The noise should go away. My clutchnet stage 2 did that also for about 3 months until it disapeared. It sounds like your doing a small burnout right? So many people turn their heads to look at me thinkin im burning rubber but my tires are not spinning
Old Apr 18, 2003 | 06:08 PM
justinCO's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">The noise should go away. My clutchnet stage 2 did that also for about 3 months until it disapeared. It sounds like your doing a small burnout right? So many people turn their heads to look at me thinkin im burning rubber but my tires are not spinning </TD></TR></TABLE>
Yea mine sounds just like a mini burnout. When my fiance first heard it that's what she thought too...
Justin
Old Apr 18, 2003 | 07:27 PM
CM-R's Avatar
man i had that noise forever on my clutchnet stage 2..it doesnt bother me anymore i got used to it...
Old Apr 18, 2003 | 08:05 PM
specie's Avatar
will a 2md for a cable B16 trans work on 92 cable USDM B18A trans (YS1)? ive tried rocket, 2k-teg, and exospeed. anyone else with some help? </TD></TR></TABLE>
The pressure plate would work, but the clutch won't.
Old Apr 18, 2003 | 08:09 PM
inspyral's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (CM-R)
I have a 1MD unsprung 6-puck. Mine doesn't make any weird noises, except for the chatter when I seriously under-rev it when taking off.
Old Apr 19, 2003 | 01:19 AM
blufke's Avatar
dont worry a bit. that clutch is great, and really smooth too.
Old Apr 19, 2003 | 10:39 AM
swlabhot's Avatar
Yep, thats what it sounds like. As its so grippy, its difficult to feather it to get a smooth engagement in slow start-stop traffic. I've got a resurfaced ITR flywheel with this clutch. I'm starting to be concern about whether its eating or doing any damage to the flywheel away over time??
Old Apr 19, 2003 | 11:43 AM
done's Avatar
does anyone have a 2ks and have any problems with it, i still have my under my bed...
ive kinda scared i might have problems with it now
Old Apr 19, 2003 | 01:13 PM
justinCO's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (Jordo)
Just so I'm not misleading anyone, the clutch does make the squeaky burnout noise every once in a while because of slipping the clutch too much. It *is not* a problem with the clutch, it works perfectly fine and I love it. Don't want anyone taking this thread the wrong way...
Justin
Old Apr 19, 2003 | 02:17 PM
swlabhot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinCO &raquo;</TD></TR><TR><TD CLASS="quote">Just so I'm not misleading anyone, the clutch does make the squeaky burnout noise every once in a while because of slipping the clutch too much. It *is not* a problem with the clutch, it works perfectly fine and I love it. Don't want anyone taking this thread the wrong way...
Justin</TD></TR></TABLE>
It does it most often when moving from standstill when engaging in 1st and 2nd under normal driving (ie. not trying to slip hte clutch or anything). If I gun it then I don't get this noise.
Old Apr 19, 2003 | 04:05 PM
Rico's Avatar
I been running the 2ks for about a month now (1200 miles) and not one problem yet, you will love it just be sure to break it in right.
Old Apr 19, 2003 | 06:41 PM
TurboSedan's Avatar
New User
Default Re: Action clutch !! noise driving me nuts!!! (Rico)
Sweet, the 2KS is the one I want to go with when I am tired of the stocker haha.
Old Apr 25, 2003 | 01:42 PM
Nikolai's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (TurboSedan)
I was *SO* paranoid about having too heavy a pedal with the 2KS, but now I'm really glad I went for it. Seriously, I got used to the pedal in like 10 minutes. I had it installed with a new CM 8.8lb chromoly f/w, and I love that, too. My tech told me it was so sweet looking from being shipped that he didn't want to install it, and that he was going to hang it on the wall instead.
The clutch is now a lot smoother (almost like stock) when engaging, now that I have about 700 miles of Austin break-in driving done on it.
The only problem I've had, and I've heard about this once before on h/t, is that yesterday in hot (it was about 95F here yesterday) stop 'n go traffic, the engagement point seemed to move further and further off the floor, until the clutch was eventually slipping, even at part-throttle. Does anyone have an explaination for this? I'm not sure how the assembly is configured, but would it be possible for the lightweight f/w, with its lower thermal inertia and likely hotter operating temperatures, to boil the fluid in the slave cylinder? With my limited hands-on Integra experience, that's the only thing I could think of........any feedback would be appreciated!!
Thx,
Nick
Old Apr 25, 2003 | 04:27 PM
94dxt's Avatar
Default Re: Action clutch !! noise driving me nuts!!! (Nikolai)
I will never go without a heavy pedal again(I hope)
Old Apr 25, 2003 | 04:48 PM
Sonny's Avatar
Update: My 1MD w/sprung disk does not chatter or make funny noises. It grabs pretty quick and hard though. The guy at the alignment shop stalled my car 4 times while trying to get it onto the racks.
Sonny
