Oiling Filter???? Need some info...
Old Jun 27, 2001 | 03:26 PM
Phat Corolla's Avatar
New User
Default Oiling Filter???? Need some info...
I've heard that you are supposed to oil the air filter on your intake before you put it on...is this true? If so, how exactly do i go about it? I figured i should check it out since I already put mine on...I don't want to screw my engine up. Thanks in advance for the info.
Old Jun 27, 2001 | 03:33 PM
blaze's Avatar
Default Re: Oiling Filter???? Need some info... (Phat GS-R)
yup. your air filter should be oiled to prevent debris from penetrating the filter. i know that K&N and some "foam" filters provide an oil to be used with their filters....
Old Jun 27, 2001 | 03:47 PM
New User
Default Re: Oiling Filter???? Need some info... (blaze)
Well, mine didn't come with any instructions about it...i'm not sure what brand it is, cuz it came with my Intake. Is there a certain kind of oil i should use? Thanks.
Old Jun 27, 2001 | 04:04 PM
LostGsr's Avatar
Most intake filter (the ones with the steel mesh folded around the filter) uses the K&N oil. Just spray evenly around and let it soak in for about 5 minutes and you are set. Here is a pic of one:
The other filter would be the foam ones which looks like a foam on a stick, they uses foam oil only.
fg2si!kid
Oct 28, 2007 04:09 AM
Jmumblez2001
Jul 26, 2006 02:32 AM
pagosa81147
Jul 6, 2006 08:27 AM
electrosi
Jan 18, 2003 08:39 PM
Nameless RB26
Jan 5, 2003 12:49 AM
