What kind of throttle body gasket is this?
Old Apr 17, 2003 | 09:32 PM
steve_meyer's Avatar
Default What kind of throttle body gasket is this?
Does anyone know what kind that is? I needed a new one and I ordered one for a GSR and it didn't fit, I am not sure where the throttle body came from, thanks fellas...
Old Apr 17, 2003 | 10:42 PM
Default Re: What kind of throttle body gasket is this? (steve_meyer)
Any ideas?
Old Apr 18, 2003 | 01:08 PM
I really need to get my car together
Old Apr 18, 2003 | 03:10 PM
ttt ;]
Old Apr 18, 2003 | 03:57 PM
Katman's Avatar
hrm...
hard to tell, but it looks kinda like a SOHC tb gasket to me...
Old Apr 18, 2003 | 03:59 PM
Lord Helmet's Avatar
Default Re: What kind of throttle body gasket is this? (Katman)
looks like my d16z6 throttle body gasket IMO. I could be wrong.
Modified by sleeperciv at 5:14 PM 4/18/2003
Old Apr 18, 2003 | 04:02 PM
Default Re: What kind of throttle body gasket is this? (sleeperciv)
Is the hole on a z6 tb gasket 2.5" across?
Old Apr 18, 2003 | 04:13 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve_meyer &raquo;</TD></TR><TR><TD CLASS="quote">Is the hole on a z6 tb gasket 2.5" across?</TD></TR></TABLE>
my math sucks but can you convert that to MM?
if its 52 or 60mm then its a B-series tb gasket....anything smaller than those sizes is more than likely a SOHC tb gasket.
I believe the image you have of the gasket is facing the wrong way, its suppose to mount up to the manifold like so:
Old Apr 19, 2003 | 02:12 AM
Its a little over 60mm, any ideas guys?
Old Apr 19, 2003 | 09:20 AM
bump bump bump
Old Apr 19, 2003 | 10:29 PM
top!
Old Apr 20, 2003 | 09:33 PM
Anyone know for sure?
Old Apr 21, 2003 | 01:17 AM
Turbo Powa's Avatar
Looks like a SOHC Tb gasket to me too....
Old Apr 21, 2003 | 05:28 AM
real9999's Avatar
Default Re: What kind of throttle body gasket is this? (Panda EK)
From what I recall (might be somewhat hazy), it does NOT look like an ls t-body gasket.
Tom
Old May 12, 2003 | 01:27 AM
iwouldHITit's Avatar
yea i think its a sohc cause dohc's map sensor it on the right
Old May 12, 2003 | 05:34 AM
CaNaBiS's Avatar
Default Re: What kind of throttle body gasket is this? (iwouldHITit)
Use the gasket you already have...just use a very small tad of RTV blue or something in the place that are torn OR get some gasket material from your local parts store and make your own.
Old May 12, 2003 | 06:26 AM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwouldHITit &raquo;</TD></TR><TR><TD CLASS="quote">yea i think its a sohc cause dohc's map sensor it on the right</TD></TR></TABLE>
map sensor?? the only holes on the gasket are for IACV and FITV.
THe "map sensor area" in that pic should be the EVAP port.
That gasket should work.
trailblazer
Jul 9, 2018 08:22 PM
bigweedy
Dec 29, 2009 01:13 PM
thedudefromjerz
Jan 25, 2008 07:05 PM
alexsracing
Aug 21, 2007 07:23 PM
eg6sir88
Jan 21, 2007 03:52 PM
