Overheating, Coolant is filled no leaks..
Old Apr 17, 2003 | 08:57 PM
hatchback's Avatar
Default Overheating, Coolant is filled no leaks..
So my gf's car was starting to overheat.
She has enough coolant, there is no leaks, and 7 months ago she got a new radiator.
Any suggestions?
Old Apr 17, 2003 | 09:01 PM
P1mpSlap's Avatar
The valve in the thermostat is broke closed.
That is one possibility and most likely. Very inexpensive fix.
Old Apr 17, 2003 | 09:10 PM
tC_Dragon's Avatar
Default Re: (P1mpSlap)
yea, my guess is that the thermostat is broken. how many miles are on the car? and when was the last time the thermostat was replaced?
Old Apr 17, 2003 | 09:12 PM
hatchback's Avatar
Default Re: (pdcdragon)
approximately 145,000..
and as far as maintenance.. It probably has not been replaced.
I think we will get a new one and see if that solves the problem.
Is it easy to replace a thermostat?
Old Apr 17, 2003 | 09:13 PM
xchosun1x's Avatar
i had a similar problem too. I replaced the radiator, thermostat, thermo switch. There were no leaks and
coolant/water level was good. turns out my head gasket and related gaskets were going and caused overheating
try a leak down..see how that turns out....hope its smaller problem...head gasket is a headache and $$$$
good luck
Old Apr 17, 2003 | 09:14 PM
P1mpSlap's Avatar
Hell, I'm guess if they had to replace the radiator, the thermostat is shot the hell too.
Time to run down to advanced auto or autozone. LOL I think mine cost me $4.99 and the gasket was $.79 cents. lol
Took me an Hour and half to ******* install it thought and I cut up my knuckles pretty bad.
Old Apr 17, 2003 | 09:51 PM
tC_Dragon's Avatar
yea, there is a good possibility that its ur thermostat... i haven't done that personally, but i have read the procedure on my helms manual and seen the posts on the board in regards to it, and i don't think its anything that is high in difficulty level, but a pain the *** i hear to reach some of the bolts.
Old Apr 20, 2003 | 09:25 PM
hatchback's Avatar
Alright guys, you were right again it was the thermostat. Got a brand new one and everything is all good now.
I hope I dont come across this many problems when I go hybrid.
Thanks again guys!
Old Apr 20, 2003 | 10:28 PM
romeo619romeo's Avatar
Default Re: (hatchback)
when you change your timing belt do your waterpump als.. might be time for it to go also LOL
Old Apr 20, 2003 | 10:30 PM
tC_Dragon's Avatar
good to hear that your problem was as simple as we anticipated.
Old Apr 21, 2003 | 01:14 AM
riceball777's Avatar
Default Re: Overheating, Coolant is filled no leaks.. (hatchback)
see if the fans are working too
ltapia707
Honda Civic (2001 - 2005)
12
Mar 19, 2013 02:57 PM
1991crx16
14
Jan 26, 2011 01:47 PM
KLUE
Oct 26, 2009 03:24 PM
soclean1k_JDM
25
Aug 6, 2008 07:23 AM
giantdny
Nov 6, 2006 07:13 AM
