Has anyone removed VSS from 4th gen hatch tranny?
From: 9/11/01 WTC Never Forget, United States Of America
So has anyone here removed the vss from 4th gen hatch tranny?
If so please tell me how iy was done
Remove the 10mm bolt, remove the little keyway plate thing.
Grab the top of the sensor, NOT THE CABLE, and wobble it while pulling upward.
It will work it's way out eventually.. It's a real pain in the *** because it's machined to be a TIGHT fit. Sometimes WD-40 helps.
Use lots of penetrating oil, and sit there for an hour wiggling the top of the VSS back and forth, side to side, to break the corrosion that has built up between the 2 pieces of aluminum. There is actually an o-ring in there, but the metal is just tight enough, that the o-ring doesn't have to work very hard to maintain the seal. However there is enough room for some good corrosion to take place, and seize it up pretty good. Be patient, or you will pull the metal piece out of the aluminum, and then you'll be fucked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker »</TD></TR><TR><TD CLASS="quote">Use lots of penetrating oil, and sit there for an hour wiggling the top of the VSS back and forth, side to side, to break the corrosion that has built up between the 2 pieces of aluminum. There is actually an o-ring in there, but the metal is just tight enough, that the o-ring doesn't have to work very hard to maintain the seal. However there is enough room for some good corrosion to take place, and seize it up pretty good. Be patient, or you will pull the metal piece out of the aluminum, and then you'll be fucked.</TD></TR></TABLE>
Whats the best tool to use for getting it out?
I did this today and your guys instructions are way too difficult. All you do is...
1. Pull off the rubber boot covering the VSS.
2. Pull off the obvious retaining clip.
3. Pull out the speedo cable, it's not even in super tight.
Thats it, not hard at all, you can do if with your bare hands.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch »</TD></TR><TR><TD CLASS="quote">I did this today and your guys instructions are way too difficult. All you do is...
Thats it, not hard at all, you can do if with your bare hands.</TD></TR></TABLE>
okay
did you remove the whole thing even the piece that is inside the tranny?
i got everything else out but that
okay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.RED'89 »</TD></TR><TR><TD CLASS="quote">
okay
Hmmm maybe you guys are talking about something else. I thought you were talking about the speedocable that goes into the sensor. I wasn't talking about the actual sensor itself, sorry my bad.
okay
yeah i was talking bout the actual piece with the little wheel at the end that goes inside the tranny.
Product # Description Total Price
91313-611-010 O-RING (23.5X2) $1.07
90638-689-000 CLIP, SPEEDOMETER GEAR $1.74
23811-PC1-000 HOLDER $14.84
23820-PM1-000 GEAR, SPEEDOMETER $22.28
Subtotal $40.56
Tax $0.00
Handling Charge $4.95
Shipping $4.63
Total $50.14
http://www.manhonda.com
As you can see, I couldn't get mine out either.
The good thing is that the parts were here in 3 days!
Subtotal $40.56
Tax $0.00
Shipping $4.63
Total $50.14
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX »</TD></TR><TR><TD CLASS="quote">Product # Description Total Price
Subtotal $40.56
Tax $0.00
Shipping $4.63
Total $50.14
So why did you have to buy a new one if u didnt get the other one out?
Subtotal $40.56
Tax $0.00
Shipping $4.63
Total $50.14
ELUD THS
Nov 19, 2001 09:24 AM
