grinding on third gear after 5000 rpms
i have a b16 on my crx when i did the swap i replaced my clutch and flywheel with a clutch masters i also dropped in a b&m short shifter i didint kill my car untill the break in period but naw when im shifting at high rpms from second to third it grinds as it goes in only in 3ed gear i dont know what it is help some people say is the short shifter
Guest
Posts: n/a
if you out shift your trans it'll grind. that can happen even w/o a short shifter. if no matter how fast you shift into gear it still grinds, your clutch may need an adjustment or your syncros are shot.
Spinks
Honda Civic (2006 - 2015)
Nov 23, 2010 06:01 PM
blackhatch13
Mar 28, 2003 03:20 PM
