Please help, Clutch problem ?
Old Apr 17, 2003 | 06:52 PM
90crxzc's Avatar
Default Please help, Clutch problem ?
Ok heres the story, i had my engine rebuilt last spring, because someone messed up on the tuning i had to get the engine done again, the rings woundnt seat, anyhow in the fall i had the engine re-done in the fall and at that time i was having problems with having a hard time getting the gear into reverse without grinding the gears so i adjusted the clutch cable and it was ok for awhile and started doing the same thing, i kept having to adjust the cable, so i decided to get a new clutch and clutch cable, the shop said they had a clutchmasters with only 5k on it and said it was in excellent shape, and now after 1000miles it starting to do the same thing(and i have been breaking the engine in so i have been babying the car) is there some other problem or did i get a bad clutch from the shop
Old Apr 17, 2003 | 07:21 PM
Chiovnidca's Avatar
Default Re: Please help, Clutch problem ? (90crxzc)
What year and model?
Old Apr 18, 2003 | 09:49 AM
90crxzc's Avatar
Default Re: Please help, Clutch problem ? (TurboD16Chiovnidca)
1990 crx with a zc engine
Old Apr 18, 2003 | 12:24 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxzc &raquo;</TD></TR><TR><TD CLASS="quote">1990 crx with a zc engine</TD></TR></TABLE>
Check your clutch pedal bracket for broken welds. While pushing on the clutch pedal with your hand, look for any movement under there that shouldn't be. This is just a longshot.
Moaltar
Oct 21, 2013 11:25 AM
QuarterMileMaster
Jul 24, 2007 12:51 PM
CRX7
Jun 9, 2006 12:32 PM
jeffruby
Apr 16, 2006 11:48 PM
sabertooth
Feb 24, 2004 08:27 AM
