95 Integra LS Sedan for $4900 ... Worth it?
Old Apr 17, 2003 | 06:13 PM
black sohc civic's Avatar
Default 95 Integra LS Sedan for $4900 ... Worth it?
hey guys, someone is offerin me a 95 ls sedan for under $5k. problem is the mileage is 133k+. other than that, the body has normal tear and wear, and the interior is super clean. i'm plannin on slappin on a vtec head and possibly boosting the motor, but with 133k miles, you think it will run well? i heard i might have problems with the compression because of the high mileage? thanks
Old Apr 18, 2003 | 04:54 AM
geminis2k's Avatar
Default Re: 95 Integra LS Sedan for $4900 ... Worth it? (black sohc civic)
Do a compression test on it, not sure what the standard is for LS motors but as long as the numbers are over 170 and are all within 15 of each other you should be fine...
Don't worry about miles, other than the actual suspension/bushings and all that other **** if the motor was well kept the car will run good..
My 94 GSR has some mileage and I have 220 PSI across the board, better than some NEWER GSR's I've seen, all about maint..
Old Apr 18, 2003 | 05:27 AM
Loveless's Avatar
i got my 94 ls sedan for 5300, comes with 60k miles.
I seriously think you can do better than 5000 but you'll have people tell you that miles don't matter. It's up to you.
Old Apr 18, 2003 | 09:53 AM
pope's Avatar
not worth it bcuz u can get a 94-95 gsr for the same $$$
Old Apr 18, 2003 | 10:00 AM
JeremyL's Avatar
Default Re: (pope)
i bought mine with 197K for less than $3k...has 231K now
i still have never gotten any kind of test on the motor comp or leak down
I Like Hondas
Sep 25, 2006 01:25 PM
LazJDM
May 24, 2006 08:24 PM
Project_EK
Jun 20, 2005 12:56 PM
Dc2 Powered
May 29, 2004 11:56 PM
E-Rok
Oct 30, 2002 04:17 PM
