Fuel Filter change
Old Apr 17, 2003 | 05:41 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Fuel Filter change
ANybody have any step by step
I know it is pressurized but the thing is I am having trouble getting the big screw off
any diagrams or pictures available
Old Apr 17, 2003 | 05:42 PM
smokinvtecCRX18's Avatar
From: yea thats right i got a flowmaster and it owns you, Oklahoma, usa
Default Re: Fuel Filter change (MugenHonda)
the banjo nut on the top of the fuel filter?
Old Apr 17, 2003 | 07:38 PM
REDBARON's Avatar
Default Re: Fuel Filter change (smokinvtecCRX18)
http://www.sfu.ca/~ims/index.html
Go to the How To's
It's not my site, but I saw it on here before.
Old Apr 17, 2003 | 08:44 PM
ScottEK's Avatar
Default Re: Fuel Filter change (REDBARON)
Fuel filter change is cake, unscrew your gas cap, grap a 12mm socket for the service bolt on the out line off the fuel filter, unscrew that, a little gas might come out. Now grab the 17mm ratchet and take off each line, use a 10mm on the bracket and pop in the new filter. Remember to use new copper washers, one on bottom and one on top of each line, and then there should also be a new one for the service bolt. The washers normally come with the filter. I think the torque on the service bolt is 7lbs and the 2 17mm lines is 20lbs. I've been doing a lot of fuel stuff this week so it's all fresh in my head.
Old Apr 17, 2003 | 08:55 PM
thaiphob's Avatar
Nikon!!!
Default Re: Fuel Filter change (beta13)
good deal. i needed some info on how to do this!
Old Apr 17, 2003 | 10:18 PM
Vinceg99's Avatar
Default Re: Fuel Filter change (thaiphob)
Anyone else run into the problem that when you go and try to loosen the banjo nuts that 2 things happen first the whole damn filter rotates and then possibly bending the metal bracket that holds it?? All 3 that I have taken off recently were a real PITA!! I just want to see if I was doing something wrong??? How did you go about loosening them without the filter rotating or bending the bracket?? I guess that it probably doesnt help that all 3 were probably the originals on the CRX's though huh??
Old Apr 17, 2003 | 10:20 PM
sporkcrx's Avatar
Default Re: Fuel Filter change (Vinceg99)
Yea, they all rotate and **** like that, i forgot what i did to make it non-bitch, but it's not too hard.
Old Apr 17, 2003 | 10:39 PM
Ham'ed Hatch
Guest
Posts: n/a
yeah that's the problem i have. i got to loosen the lines and the whole thing bends. i just said screw it.
Old Apr 17, 2003 | 10:41 PM
Vinceg99's Avatar
Default Re: Fuel Filter change (Ham'ed Hatch)
Well that makes me feel better that I wasnt the only one with the problem you would have thought that Honda would have came up with a better holder for the fuel filter and well some quick connects would have been nice also....
Old Apr 17, 2003 | 11:35 PM
Mr.Saturn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else run into the problem that when you go and try to loosen the banjo nuts that 2 things happen first the whole damn filter rotates and then possibly bending the metal bracket that holds it?? All 3 that I have taken off recently were a real PITA!! I just want to see if I was doing something wrong??? How did you go about loosening them without the filter rotating or bending the bracket?? I guess that it probably doesnt help that all 3 were probably the originals on the CRX's though huh??</TD></TR></TABLE>
I don't have the exact fuel line layout in my mind but isn't this what flarenut wrenches are for?
Old Apr 18, 2003 | 06:32 AM
Vinceg99's Avatar
Default Re: Fuel Filter change (Mr.Saturn)
When you say a flarewrench arent you talking about a line wrench? Basically a box end with a cut-out? Like a brake line wrench? If thats what your talking about I dont see how that would help?? I mean all it is is that the banjo bolts are just so tight and the filter twists and bends the holder that the fuel filter is in.
Old Apr 18, 2003 | 07:01 AM
zCivic's Avatar
I always just grabed on of the lines on the metal part to keep it from spinning. I've never had any problems with that or grab a oil filter wrench and hold on to the filter your gonna trash it anyways, just a suggestion for ya'll
Modified by zCivic at 11:28 AM 4/18/2003
Old Apr 18, 2003 | 07:12 AM
drjondurst's Avatar
I had this problem. I just said "ok, its gonna come off.. if the bracket breaks oh well, but the lines are comming off"
So I put a 2 foot pipe on the end of my ratchet and just gave it a good jerk and it came loose. Yes the bracket was bending like all hell, but its still sitting in there straight till this day. Maybe those things are built well enough not to break under all that bending.
Old Apr 18, 2003 | 09:57 AM
IamVtec's Avatar
i just recently replaced mines. Just make sure that the screw to the braket that is holding the fuel filter is really on there tight so that it wouldnt rotate easily. And yes the braket will bend but i think it pretty tough. It shouldn't break unless your twisting the whole thing 360
Old Apr 18, 2003 | 11:19 AM
Mr.Saturn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">When you say a flarewrench arent you talking about a line wrench? Basically a box end with a cut-out? Like a brake line wrench? If thats what your talking about I dont see how that would help?? I mean all it is is that the banjo bolts are just so tight and the filter twists and bends the holder that the fuel filter is in.</TD></TR></TABLE>
Yah thats what a flarenut wrench is, but like I said, I didn't know how the fuel filter is layed out in my head. I know a lot of cars need the flarenut wrench for fuel lines though, just a guess, sounds like it was wrong though.
Old Apr 19, 2003 | 08:16 AM
Vinceg99's Avatar
Default Re: Fuel Filter change (zCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">or grab a oil filter wrench and hold on to the filter your gonna trash it anyways, just a suggestion for ya'll</TD></TR></TABLE>
Thats a good idea I never thought of that I guess one of those plier type oil filter wrenches would work wonders the only problem is if its really tight and you need both hands to get the damn line loose.
mrredrocker
16
Oct 6, 2005 10:45 PM
2kstreetcivic
Jan 18, 2005 07:42 PM
Ti3d in
Jul 27, 2004 07:57 PM
get wet racing
Jan 6, 2003 06:16 AM
AK94GSR
Aug 7, 2002 08:02 PM
