Which one do I buy and how do I connect an MSD Coil
Old Apr 17, 2003 | 05:24 PM
DavidTurbo's Avatar
Default Which one do I buy and how do I connect an MSD Coil
I need to get an MSD coil for my 95 LS wiring because when I got the ignition the guy before me had one and he took the stock one out. Which one do I buy and how do I hook it up. He also had an MSD 6AL but I don't want to get one right now (no $). let me know thanks
Old Apr 17, 2003 | 05:30 PM
slomofo's Avatar
GDD Member
Default Re: Which one do I buy and how do I connect an MSD Coil (DavidTurbo)
Do you have the stock distributor cap? If so, then buy a stock coil and throw it in.
If you have an MSD Pro-Cap with power tower(I dunno why the hell they call it that), then go and buy an MSD Blaster 2 or better and run your coil wire to the coil as usual, the coil will have two terminals on it, run the negative wire inside your distributor to a Square eye connector that has two wires coming off of it, run your positive terminal wire inside the cap to a wire with a one wire round eye connector. Kinda hard to explain, i'll try and take pics for you.
Old Apr 17, 2003 | 10:21 PM
DavidTurbo's Avatar
Default Re: Which one do I buy and how do I connect an MSD Coil (slomofo)
I want to buy an MSD cap and coil, I just found them at Manchester Motorsports for $45 coil and $29 the cap but I don't know how to hook them up.
Old Apr 21, 2003 | 08:56 PM
DavidTurbo's Avatar
Got them hooked up and it was fairly easy, thanks for you help!
dmotoguy
Jul 29, 2008 08:22 PM
r1ch1e
Aug 30, 2007 11:12 AM
dc4teg95
Nov 23, 2006 07:37 AM
piggypen
Feb 12, 2005 04:13 PM
WeaponR
Apr 4, 2004 09:44 PM
