koni yellow problem (please help, i'm installing tomorrow)
Old Apr 17, 2003 | 04:42 PM
siciliani's Avatar
Default koni yellow problem (please help, i'm installing tomorrow)
i recently bought a used (for 1 year) set of koni yellows. since i'm planning on installing them this weekend, i pulled them out to have a look. i tried putting the **** on and giving them a turn to see what it was going to be like, but it just keeps spinning around and around. there doesn't seem to be any point of resistance or any 'stopping point'. i can spin the **** 10 or 15 times around (both directions) and it doesn't stop. is this normal? the directions say the difference between fully firm and soft is 1.5 turns. why can i turn it so much more than that?
are they f-ked up or what?
Old Apr 17, 2003 | 04:45 PM
slomofo's Avatar
GDD Member
Default Re: koni yellow problem (siciliani)
Don't know your answer, but I'd never buy used struts. Struts only have a 12,000 mile life on them so if they've been used for one year, I wouldn't even run them.
Old Apr 17, 2003 | 04:56 PM
siciliani's Avatar
Default Re: koni yellow problem (slomofo)
it's a little late for that advice
it's like that on ALL four. what are the chances this dude blew all four shocks?
Old Apr 17, 2003 | 04:58 PM
hs2000's Avatar
I just got a new set of koni yellows and it says that you can turn it to stiffen it as many turns as possible but you should not turn them more then one full turn but if you turn them the other way it should stop. you may have broken them turning them 15 times...sucks...It would not worry about them being used because koni's are tuff. Do you mind if I asked how much you payed for them?
Old Apr 17, 2003 | 05:01 PM
siciliani's Avatar
Default Re: koni yellow problem (hs2000)
why wouldn't they stop? without a stopping point, how do you know how firm they are?
Modified by siciliani at 7:25 PM 4/18/2003
Old Apr 17, 2003 | 05:09 PM
hs2000's Avatar
I think maybe they are broke. Call koni, see what they say.
I got my set of konis for 375 shipped NEW
Edit:Got them off ebay.
Modified by hs2000 at 3:04 PM 4/18/2003
Old Apr 17, 2003 | 06:15 PM
Tweakmeister's Avatar
ask Lee >> he's a Koni guy...hangs out on the RR forum a bit (drives a CRX).
I forget his username
poormanstyperb16
Suspension & Brakes
14
Oct 28, 2010 12:56 PM
JDM RHD eg6
Suspension & Brakes
14
Feb 1, 2005 10:21 AM
gsr-mike
Jun 18, 2004 05:55 PM
Muckman
Jul 5, 2003 07:52 PM
siciliani
Apr 18, 2003 11:18 AM
