93 Accord ex makes weird noise when moving backwards.
Old Apr 17, 2003 | 02:30 PM
Jedi_Sol's Avatar
Default 93 Accord ex makes weird noise when moving backwards.
I've got a 93 Accord ex auto tranny that is making a mixture of a grinding/whining/two pieces of-metal-rubbing-against-each-other kind of noise when the car goes backwards. I thought at first it was the transmission because it makes the noise when i put it into reverse, but it also does it when the car is in neutral and i am just rolling backwards down a hill. The car also rumbles violently when the car idles in reverse. does this sound like a transmission problem? your input would be appreciated.
Old Apr 18, 2003 | 03:01 AM
93acclude's Avatar
Default Re: 93 Accord ex makes weird noise when moving backwards. (Jedi_Sol)
check your brakes.
Old Apr 18, 2003 | 10:13 AM
YeuEmMaiMai's Avatar
check your motor mounts for the ruble idle while in reverse
check your rear brakes and replace all worn parts
regular_guy_49
Jan 30, 2011 01:50 PM
bigginsUT
Dec 15, 2009 10:05 PM
goobernoodles
Apr 26, 2009 12:23 PM
jzweig
Feb 11, 2008 04:46 AM
Spider Man
Mar 14, 2004 10:39 AM
