99 Accord lx having problems with digital clock
Old Apr 17, 2003 | 01:02 PM
naujcdl's Avatar
Default 99 Accord lx having problems with digital clock
when you installed your aftermarket head unit in a 6th gen accord, did you have problems with the clock not lit up when at night and lights on. i mean, i have to tap that clock for it to lit. let me know if you had this problem and give some good feedback.
Old Apr 17, 2003 | 01:58 PM
Chiovnidca's Avatar
Default Re: 99 Accord lx having problems with digital clock (naujcdl)
Replace the bulb.
Old Apr 17, 2003 | 03:24 PM
naujcdl's Avatar
Default Re: 99 Accord lx having problems with digital clock (TurboD16Chiovnidca)
well, i dont know if i have to replace the bulb, because it still goes on, but i guess it is something inside of the clock not functioning right...
keep suggestions coming. it is the digital clock from the new accords 99.
Old Apr 17, 2003 | 05:16 PM
iam7head's Avatar
the blub burn out, but you need to replace the whole clock, it cost 12 bucks at honda. The blub is built inside according to the guy work in honda, cant be taken apart.
Old Apr 17, 2003 | 05:25 PM
Chiovnidca's Avatar
Default Re: 99 Accord lx having problems with digital clock (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">the blub burn out, but you need to replace the whole clock, it cost 12 bucks at honda. The blub is built inside according to the guy work in honda, cant be taken apart.</TD></TR></TABLE>
The guy you talked to is a dumbass. They have a replacable bulb. Honda even has a service bulletin on it.
Old Apr 17, 2003 | 06:24 PM
jweller's Avatar
yup, there is a bulb
check that the wires are plugged up tight. The clock has to be removed to get to the radio.
Old Apr 17, 2003 | 06:30 PM
toadlax's Avatar
Default Re: 99 Accord lx having problems with digital clock (jweller)
mine doesnt light up at all ever, its a 99sedan lx
Old Apr 17, 2003 | 06:32 PM
naujcdl's Avatar
Default Re: 99 Accord lx having problems with digital clock (toadlax)
yep i was just looking to see what you people thought about this issue, i just want to know what to do about it. keep suggestions coming.
Old Apr 17, 2003 | 06:35 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by naujcdl &raquo;</TD></TR><TR><TD CLASS="quote"> i just want to know what to do about it. keep suggestions coming.</TD></TR></TABLE>
What don't you understand?
Old Apr 17, 2003 | 08:51 PM
Heat's Avatar
Just take it out, whack it against your leg a couple of times, take a look for the bulb and make sure it's tight, then put it back in. If that doesn't work, remember that you can pick up a new clock for under $20 from Honda.
I assume you know how to remove the clock, right? Put some masking tape just under the clock on your dash, wrap the head of a flathead screwdriver a couple of times with masking tape, and gently pry up from the bottom of the clock assembly. The masking tape is to make sure you don't scratch your dash.
Old Apr 17, 2003 | 09:10 PM
naujcdl's Avatar
Default Re: (Heat)
well, if it comes back up again with problems, i just replace the light bulb
later.
archGrem
Mar 13, 2018 07:37 AM
Xavier Davis
Jul 31, 2015 04:28 PM
myhondasrusty
Feb 21, 2010 06:32 PM
Donboss
Sep 27, 2006 11:10 AM
