Just picked up some coilovers, what are these things that came with it???
Old Apr 17, 2003 | 12:49 PM
Red_Si's Avatar
Default Just picked up some coilovers, what are these things that came with it???
Hey i just picked up a set of DropZone coilovers, they look like they are made of pretty good quality if anybody wants to know. Anyways, what are these little black circular rubber gasket thingies and what do they do? do i need them? anybody have a detailed how to on how to install these?
Old Apr 17, 2003 | 12:58 PM
KevronsEG's Avatar
Default Re: Just picked up some coilovers, what are these things that came with it??? (Red_Si)
yes they are good coilovers. if you try to put them over your strut you will see they bang around cause teh sleve is to big. so you use the rubber to make it fit stung and be centered on teh strut. I love my drop zones
Old Apr 17, 2003 | 01:03 PM
zcivicz's Avatar
those things you put between the spring and the perches so it doesn't rub and squeak! they go on top and the bottom of the springs here is the order
starting from the bottom...bottom perch-gasket-spring-gasket-top perch
hope that helps
Old Apr 17, 2003 | 05:31 PM
Red_Si's Avatar
Default Re: Just picked up some coilovers, what are these things that came with it??? (zcivicz)
but i have a bunch for each coilover, there is probably 10-15 of them per coilover???
Old Apr 17, 2003 | 07:02 PM
B18A1crx88's Avatar
if you look at them they should be different sizes...use 2 of which ever fit the best for each strut, and put the others somewhere incase a friend needs them some day..thats what i did and a friend actually needed a few one time...
Old Apr 18, 2003 | 07:00 AM
zcivicz's Avatar
hey man i'm in need of 2 of those things actually for my coilovers cuz 2 of them ripped apart and i can't get them anywhere! if you can send me a couple that would be great!
Old Apr 20, 2003 | 09:17 AM
Red_Si's Avatar
ok, after looking these back over it looks like i only have the black rubber things for the rear??? But there are still about 20 of them. For the front i have a white paper type gasket i guess, what are these??? Please help these are supposed to go on today!!! it would really work if someone had a detailed how to on how to install these? thx
BastardZ24
Suspension & Brakes
41
Aug 10, 2012 01:37 PM
Zac86
Suspension & Brakes
Jul 1, 2007 05:32 PM
pizzle
Suspension & Brakes
18
Mar 22, 2007 08:48 AM
krnboynemesis
Jun 12, 2005 12:56 PM
IRev2NineK
12
Jan 5, 2005 09:45 PM
