reduce wheel hoping?
Old Apr 17, 2003 | 12:43 PM
b18c51032000's Avatar
Default reduce wheel hoping?
what are some of the ways to reduce wheel hoping at launching ?
Old Apr 17, 2003 | 12:53 PM
joe_bocc's Avatar
Default Re: reduce wheel hoping? (b18c51032000)
traction bars are a good way to reduce wheel hop.
http://www.jimfab.com
http://www.z10eng.com
These are 2 places that sell them.
Old Apr 17, 2003 | 01:01 PM
TurboSedan's Avatar
New User
Default Re: reduce wheel hoping? (joe_bocc)
....reinforcing the motor mounts (ES inserts) will help as well.
Old Apr 17, 2003 | 01:10 PM
torr's Avatar
Default Re: reduce wheel hoping? (TurboSedan)
hope it doesn't do it
Old Apr 17, 2003 | 02:44 PM
BodeB15's Avatar
Default Re: reduce wheel hoping? (torr)
Filled motor-mounts . Quite a few Spec-V owners are having their motor-mounts filled with urethane . I have major wheel hop on my SE , no LSD with the automatic tranny .
Old Apr 17, 2003 | 02:54 PM
Nissmaxx's Avatar
Default Re: reduce wheel hoping? (BodeB15)
I have heard that there is a way to fill the motor mounts with a construction grade caulking this is the "ghetto way of doing it" anyhow traction bars are extremly helpful. If you have the money then just buy the polyurethane motor mounts from a aftermarket company....
Old Apr 17, 2003 | 03:04 PM
SamC's Avatar
Default Re: reduce wheel hoping? (Nissmaxx)
will the jimfab bar clear a spoon header?
Old Apr 17, 2003 | 06:24 PM
DK4200's Avatar
Default Re: reduce wheel hoping? (SamC)
spend 30-40 bucks and get Energy suspension motor mount inserts and don't do it the "ghetto" way.... thats just rediculous
Old Apr 17, 2003 | 08:56 PM
egg's Avatar
egg
Default Re: reduce wheel hoping? (DK4200)
not that its ghetto, but from my experience, filling motor mounts works better than the ES inserts
Old Apr 17, 2003 | 09:13 PM
RoadRage's Avatar
Default Re: reduce wheel hoping? (egg)
I use to have a link to filling the motor mounts. If you go that route, use the 3M window urethane.
Old Apr 18, 2003 | 04:41 AM
BodeB15's Avatar
Default Re: reduce wheel hoping? (RoadRage)
3M window urethane , thanks that's the product I couldn't think of .
Old Apr 18, 2003 | 05:15 AM
gitwidit's Avatar
What sort of suspension settings are best to reduce wheel hop, some say stiffen
the back and soft on the front, what works best?
Old Apr 18, 2003 | 06:04 AM
RoadRage's Avatar
Default Re: reduce wheel hoping? (GITWIDIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">What sort of suspension settings are best to reduce wheel hop, some say stiffen
the back and soft on the front, what works best?</TD></TR></TABLE>
That's what I've always heard, With adjustable shocks, set the rear shocks very stiff and the front shocks very soft. And that helps keep the front end planted (rears stiff) and helps prevent wheel hop (fronts soft).
Old Apr 18, 2003 | 03:45 PM
BodeB15's Avatar
I would put Teins on my SE , Eibach sway-bar kit .
Modified by BodeB15 at 10:02 AM 4/19/2003
Old Apr 18, 2003 | 03:55 PM
Katman's Avatar
along with the other suggestions on this thread, I believe better than stock suspension would help decrease wheel hop.
civicsaremean
18
Jul 23, 2007 11:17 AM
slofton
Mar 20, 2007 05:27 AM
elitesi8
Oct 9, 2005 06:42 AM
Azcheron
Apr 18, 2005 11:45 AM
jbscivichb92
Oct 29, 2004 07:49 AM
