When lowering the car,,do I need any other things
Old Apr 17, 2003 | 10:47 AM
spartu5's Avatar
Default When lowering the car,,do I need any other things
I plan to get lowering springs on my HB very soon and I need to know if there is anything else I need to do like new shocks,struts ect. I am kinda new to all this so bear with me.
Any other info will be super helpful also
Old Apr 17, 2003 | 10:53 AM
shorti's Avatar
Default Re: When lowering the car,,do I need any other things (spartu5)
get new struts or else you'll blow your stock ones
it would be better to spend more money now than to hassle over it later
Old Apr 17, 2003 | 11:27 AM
Ef Whore's Avatar
Default Re: When lowering the car,,do I need any other things (shorti)
Exactly---upgrade to the shock of your choice fo sho'. If you have a little cash laying around, I would suggest Blues for the front, Illumina's set to 3 for the rear. Thats my preference anyways. I would also suggest you replace your balljoints/ rod ends/bushings in the process cause they are going to go quickly if they are the originals when you lower the car. But at least for now get the shocks.
Old Apr 17, 2003 | 11:31 AM
Crxer's Avatar
koni yellows with skunk 2's
if you dont want to spend big bucks on the shocks i heard that kyb agx's and bilsteins are good also. i know the koni's are good from experience
Old Apr 17, 2003 | 11:45 AM
Ef Whore's Avatar
Default Re: When lowering the car,,do I need any other things (Crxer)
If your drop is not going to be that severe, at least get anything aftermarket. But what I suggested in my previous post is a real tight setup.
Old Apr 17, 2003 | 12:41 PM
REDBARON's Avatar
Default Re: When lowering the car,,do I need any other things (Ef *****)
A big factor is how low you plan on lowering the car. Different ride heights will require different things.
Old Apr 17, 2003 | 01:02 PM
spartu5's Avatar
Default Re: When lowering the car,,do I need any other things (REDBARON)
well i planned on lowering the car 1.7 in. in front and 1.6 in back..the eibach touring kit.
Can someone give me a website on where to find some good struts?
Old Apr 17, 2003 | 01:34 PM
REDBARON's Avatar
That drop is not too severe, so any aftermarket shock should be good enough.
You can try http://www.shox.com
They have good prices.
You can also get a camber kit to help with the increased negative camber you're going to get. It's not necessary, but it will make your tires last longer.
Old Apr 17, 2003 | 04:29 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
yo i got my tokico blues and eibach pro-kit in the mail, so when I install them (1.2 drop up front, 1.0 in the back) will I need a camber kit?
Old Apr 17, 2003 | 06:19 PM
Quik89Si's Avatar
Default Re: When lowering the car,,do I need any other things (SeaBass)
Nope. You will more than likely need an alignment though. The biggest problem with tire wear is not camber as much as it is toe in or out. That will wear the tires down far quicker.
I have neuspeed sports without a camber kit and it's fine.
Alex
Old Apr 17, 2003 | 07:04 PM
spartu5's Avatar
Default Re: When lowering the car,,do I need any other things (Quik89Si)
the hb is not the wagon right? cuz i think there is an actuall 4door wagon right?
sorry about the stupid Q but i saw that some of the shocks were x-cluding wagon. thanks 4 puttin up w/ me.
Also I was looking at the Blistein AGX ajustable shocks , do i want the ones that have 4 positions or 8 positions?
Old Apr 17, 2003 | 07:06 PM
spartu5's Avatar
stupid.. I MEANT KYB SHOCKS
Old Apr 17, 2003 | 08:58 PM
Quik89Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spartu5 &raquo;</TD></TR><TR><TD CLASS="quote">the hb is not the wagon right? cuz i think there is an actuall 4door wagon right?
Also I was looking at the Blistein AGX ajustable shocks , do i want the ones that have 4 positions or 8 positions?</TD></TR></TABLE>
You are correct. The HB is the HB, the wagon is the wagon. Two different beasts entirely.
For the KYB's, I believe the ones for the CRX and hatch only have 4 positions in front and rear. However, the AGX's for the 96-00 Civics have 8 in front and 4 in rear. You want whichever ones will fit your car properly.
Alex
Old Apr 17, 2003 | 09:27 PM
bfrank81's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaBass &raquo;</TD></TR><TR><TD CLASS="quote">yo i got my tokico blues and eibach pro-kit in the mail, so when I install them (1.2 drop up front, 1.0 in the back) will I need a camber kit?</TD></TR></TABLE>
This is the setup that I have. They will settel in a little lower.. You will need a camber kit if you do not to unevenly wear your tires. Personally I do not have one! That is a nice setup BTW you will not regret it!
JonDick
Suspension & Brakes
13
Sep 20, 2010 09:38 PM
92eg412
Suspension & Brakes
Jun 10, 2009 07:15 AM
doglovindork
Sep 15, 2004 09:50 PM
92accordproject
May 4, 2003 07:53 PM
imonkie
Sep 8, 2002 10:35 PM
