Suspension, lowering, camber correction.
Old Apr 17, 2003 | 10:35 AM
justBLZE's Avatar
Chopper 2 Hopper
Default Suspension, lowering, camber correction.
Can a shop get my aligment in between specs with a 2" drop in the front? or is the front camber kit needed too?
Thinking about getting ingalls rear camber kit. There are two I could buy. If I want to drop the rear 1.8 inches, Im gonna need the more expensive one that corrects camber -2° +3° ?
Is this correct?
Should I get it done by a pro, or do it myself with my friends?
Is it hard to get an aligment with a lowered car?
Are there any shops that will do parts install like that?
Thats lots of questions, thanks in advance.
Old Apr 17, 2003 | 11:14 AM
Takeoff's Avatar
Default Re: Suspension, lowering, camber correction. (tommySI)
You need a camber kit for the front or back if you want to adjust it. I suggest you install the camber kit yourself (it is simple) and take it to a shop for alignment.
Old Apr 17, 2003 | 11:46 AM
KOALA YUMMIES's Avatar
Default Re: Suspension, lowering, camber correction. (Takeoff)
Yeah, I had a 2" drop on my integra. It will still go on the alignment rack. I had -2.2 and -2.4 degress in the front. The Toe sometimes needs to be corrected after a drop too.
hatch_
Feb 10, 2009 09:25 PM
Ran4it2
May 19, 2008 02:37 PM
siguy9900
16
May 13, 2008 07:05 PM
BJA86
11
Sep 2, 2007 01:00 PM
dom93hatch
Apr 19, 2003 10:26 PM
