Best place to purchase Oil drain plug?
Old Apr 17, 2003 | 06:55 AM
dazz's Avatar
Default Best place to purchase Oil drain plug?
I need to replace the current one (leaking oil.)
Any suggestions?
Old Apr 17, 2003 | 06:58 AM
Ef Whore's Avatar
Default Re: Best place to purchase Oil drain plug? (dazz)
Honda dealership-$2, $.50 for the washer. Or pep boys has oem plugs or oversized as well. They are not hard to find, suprised u posted.
Old Apr 17, 2003 | 07:04 AM
oldskool_rex's Avatar
90009-ph1-000 at the honda dealer. AND DON"T FORGET THE WASHER! You gotta change that every time or it will srip out your oil pan. 94109-14000
The torque on the drain plug is only like 15 ft-lbs, so don't over tighten (this is for everyone).
Old Apr 17, 2003 | 07:05 AM
Shawn C's Avatar
In The Garage
Default Re: Best place to purchase Oil drain plug? (Ef *****)
http://cgi.ebay.com/ebaymotors...=6755
they are definitely worth it. but all things aside, you probably just need to replace the aluminum crush gasket (washer). you could go anywhere, i bet an oil-change place would even GIVE you one.
Old Apr 17, 2003 | 08:19 AM
Vinceg99's Avatar
Default Re: Best place to purchase Oil drain plug? (22lbGS-R)
I went to the Honda dealer to get the washers since I was using some aftermarket plastic one for like ever but once it cracked I figured that I would replace it and when I went there the guy just gave me like a handfull of them for free.
rdean
Honda Civic (2001 - 2005)
Mar 26, 2011 01:09 PM
ahloung
14
Mar 14, 2006 10:29 AM
t0ekn3e
19
Mar 22, 2004 12:16 PM
shortyz
12
Dec 18, 2002 02:55 PM
Fooman
Sep 18, 2001 07:29 PM
