when do you change P/S fluid
Old Apr 17, 2003 | 06:15 AM
jweller's Avatar
Default when do you change P/S fluid
Somebody asked me and I didn't have any idea. I looked it up, or tried to, but it's not in the owners manual or the Helms.
Is it just something that is basically designed to last the life of the rack/pump.
Old Apr 17, 2003 | 08:19 AM
briq4's Avatar
Default Re: when do you change P/S fluid (jweller)
I've only ever checked mine and it's never been added to. 1993 Honda Accord with 264,000 miles.
Old Apr 17, 2003 | 08:24 AM
rick_spiff's Avatar
Default Re: when do you change P/S fluid (briq4)
Once every 2 years or ~30,000 miles.
P/S fluid DOES deteroriate. SLOWLY. It's a good idea to occasionally replenish it, just as you occasionally flush your brake fluid (same maintenance period).The problem is that there is no facility for evacuating the system on modern cars.
At the very least, get a bulb syringe/turkey baster and pull as much fluid as possible from the resivior, then fill up with clean fluid. Repeat. That should do work just fine.
Old Apr 17, 2003 | 02:09 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">Somebody asked me and I didn't have any idea. I looked it up, or tried to, but it's not in the owners manual or the Helms.
Is it just something that is basically designed to last the life of the rack/pump.</TD></TR></TABLE>
Honda doesn't have a recomended replacement intetrval. Ive never seen a problem caused by old fluid.
sadakoyamahonda
Dec 2, 2018 09:42 AM
Canucksfan101
Feb 2, 2015 10:05 AM
H22CD
Apr 21, 2006 08:16 AM
Jon D
12
Jan 22, 2004 07:07 AM
IntEGNYC
Aug 5, 2003 05:56 PM
