SOHC ZC and D16a6..cousins or brothers?
Old Apr 17, 2003 | 05:17 AM
Superhatch's Avatar
Default SOHC ZC and D16a6..cousins or brothers?
I have a sohc ZC in my 90 right now, its got an A6 header, intake mani, ecu (etc.) on it. I also have a p&p A6 head waiting for a home.
I was always under the impression that the 2 engines were the same aside from pistons/cams. I assumed that swapping the A6 head onto the ZC would up the compression considerably (used that c-speed chart) and everything would line right up. But I was informed this weekend that the head bolts DON'T line up and the heads are not interchangeable...
Does anyone know for sure?
-Jake
Old Apr 17, 2003 | 10:29 AM
CimorelliCRX's Avatar
Default Re: SOHC ZC and D16a6..cousins or brothers? (Superhatch)
from my understanding the heads have the same bolt pattern. The DOHC ZC does not have the same bolt pattern. Well it does have the same pattern, just the bolts are bigger for the DOHC. But I am about 99% sure the SOHC will work.
Old Apr 17, 2003 | 11:04 AM
Malgerus's Avatar
Default Re: SOHC ZC and D16a6..cousins or brothers? (CimorelliCRX)
I also think that they're brothers. They're basically the same engine, just that the sohc ZC makes more power and has a slightly different cam and pistons.
Old Apr 17, 2003 | 11:20 AM
Ef Whore's Avatar
Default Re: SOHC ZC and D16a6..cousins or brothers? (Mr. S)
Whoever is giving you that info clearly has their head up their ***---the bolt patterns are identical. What the sohcZC has over the a6 is a slightly more aggressive cam, domed-shaped pistons, and about 10 more hp give or take a couple. Slap your a6 head on, and use a metal y8 head gasket and you'll have a mean little 1.6.
Old Apr 17, 2003 | 12:01 PM
Superhatch's Avatar
Default Re: SOHC ZC and D16a6..cousins or brothers? (Ef *****)
Well that info came from a pretty reputible shop owner in the madison area. I didnt want to take my head off w/o knowing for sure. I have to repopulate the p&p head, and then Ill use the ZC cam and let you guys know how things turn out.
-Jake
Old Apr 17, 2003 | 12:07 PM
Urban Business
Guest
Posts: n/a
why would the a6 head up the compression vs the zc head? your a6 head milled?
Old Apr 17, 2003 | 12:48 PM
Sonny's Avatar
I think the shop is confusing the SOHC ZC and the DOHC ZC heads. The bolt patterns are different between the two. The SOHC ZC head has the same pattern as the D16A6 head (88-91 Civic/CRX Si). The DOHC ZC head has the same pattern as the D16A1 (86-89 Integra) head.
Sonny
Old Apr 17, 2003 | 03:19 PM
4drEF's Avatar
Keyboard Humorist
Default Re: SOHC ZC and D16a6..cousins or brothers? (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Sonny</TD></TR></TABLE>
Old Apr 17, 2003 | 03:29 PM
Outsane's Avatar
Default Re: SOHC ZC and D16a6..cousins or brothers? (4drEF)
I have a SOHC ZC head on d16a6 block in my car right now..
i got this CRX this way
Old Apr 18, 2003 | 07:27 AM
Superhatch's Avatar
Default Re: SOHC ZC and D16a6..cousins or brothers? (Outsane)
Cool...thanks guys
-Jake
Old Apr 18, 2003 | 07:30 AM
FourthGenHatch's Avatar
I second the confusing between DOHC and SOHC ZC. When most people think ZC they think the DOHC one so that guy is probably just confused.
89hbcivicguy
Aug 9, 2005 06:04 PM
benjaminenjamin
Nov 8, 2004 03:00 PM
bcphatchback
Oct 9, 2004 07:14 PM
dingusjt
Oct 2, 2003 08:54 AM
Si_Power
Jul 12, 2003 10:15 PM
