Timing Belt and Water Pump Change on an H23. Suggestions Please !!!
Old Apr 17, 2003 | 05:10 AM
NXSpoon's Avatar
Default Timing Belt and Water Pump Change on an H23. Suggestions Please !!!
On Monday I will be working on my sis's 95 Prelude Si, w/ the H23 motor. According to her mechanic she is losing coolant by the water pump and oil (probably from the cam seals). So rather than pay over $900, she is going to let me do it.
While I have done a timing belt/water pump on my car, a 99 Civic Si w/ B16, I fear that this will be more difficult due to even less open space in the engine bay.
Any suggestions or tricks that any of you can provide would be greatly appreciated. The following is the list of parts that are on order now.
Helms Manual
Timing Belt
the other belt by the timing belt
Water Pump
valve cover gasket set
cam seals
Upper and lower rad hoses
Tensioner
Anything else??
Thanks a lot.
Old Apr 17, 2003 | 05:38 AM
Sephro's Avatar
Default Re: Timing Belt and Water Pump Change on an H23. Suggestions Please !!! (NXSpoon)
I just changed my timing belt and water pump earlier this week. Not to difficult just takes a long time. If you look in the Helms it talks about pins to lock the cams with cyl 1 TDC. Make sure you have those pins because they are very useful. Air tools would be very helpful but not necessary to get the pulley off. (159ft/lbs) also make sure you have a torque wrench that will go that high. Also in the Helms they recommend that you replace the seal around the adjuster nut. I didn't because mine was in good shape. Other than that just have time....
Old Apr 17, 2003 | 01:07 PM
del_parker's Avatar
you probably want to check/adjust the valve clearances after you're done.
Old Apr 17, 2003 | 02:44 PM
NXSpoon's Avatar
Default Re: Timing Belt and Water Pump Change on an H23. Suggestions Please !!! (Sephro)
Thanks a lot guys !!! SEPHRO what adjuster nut, for the timing belt?? And the Helms will tell me what those pins are called right?? My Helms should be here tomorrow so I can review the procedure.
Anyone else have any experience??
Old Apr 17, 2003 | 10:39 PM
NXSpoon's Avatar
Back up for the "Night Shift"
Old Apr 18, 2003 | 12:10 AM
del_parker's Avatar
i used allen wrenches instead of push pins
Old Apr 18, 2003 | 12:20 AM
NXSpoon's Avatar
Default Re: Timing Belt and Water Pump Change on an H23. Suggestions Please !!! (del_parker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">i used allen wrenches instead of push pins</TD></TR></TABLE>
OK, that'll work !!! God only knows I have plenty of Allen wrenches !!!
So basically, just take my time, follow the Helms and it will go OK, right??
Nothing too demanding, just very time consuming.
Thanks !!!
Old Apr 18, 2003 | 12:29 AM
del_parker's Avatar
pretty much...
and make sure they sent you the right belt. the guy that packaged mine transposed 2 numbers...totally different belt!
Old Apr 18, 2003 | 01:20 AM
NXSpoon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">pretty much...
and make sure they sent you the right belt. the guy that packaged mine transposed 2 numbers...totally different belt! </TD></TR></TABLE>
And I can do this how?? Call a different dealer?? O r I guess just line up the old vs. new belt and count the teeth??
Thanks for all the help, my mind is a little more at ease now.
Old Apr 18, 2003 | 06:13 AM
Sephro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXSpoon &raquo;</TD></TR><TR><TD CLASS="quote">Thanks a lot guys !!! SEPHRO what adjuster nut, for the timing belt?? And the Helms will tell me what those pins are called right?? My Helms should be here tomorrow so I can review the procedure.
Anyone else have any experience??</TD></TR></TABLE>
The adjuster nut is for the tentioner. When you look above and to the right of the crank pulley you will see it sticking out from the lower cover. I used allen wrenches at first instead of the pins but it still had some play which is fine just I found it easier to use something that fit in there better. I actually used drill bits. The end that goes in the drill since it is smooth. Yes you do want to adjust the valves but it tells you to do that in the Helms. Fairly easy job to do. Don't sweat it. Just give yourself plenty of time and don't rush it. Folow the directions step by step and it will go smoothly.
Falloutkid90
Honda Civic (2001 - 2005)
Mar 19, 2024 07:30 AM
Nimrod91
May 16, 2015 02:40 PM
00BLKBB6
Aug 13, 2005 04:15 AM
balbowskie187
Apr 11, 2005 06:22 AM
