I have no idea... do you?
Old Apr 16, 2003 | 11:13 PM
visual's Avatar
Modified by visual at 10:43 PM 1/5/2007
Old Apr 16, 2003 | 11:40 PM
PreludeRacer023's Avatar
Default Re: I have no idea... do you? (visualvb)
you getting any CELs? sounds like a MAP sensor acting up or something along those lines..peace
Old Apr 17, 2003 | 05:59 AM
JTCdudeman's Avatar
Master H Technician
i would sya map too, but if ur throwing no codes(check to c if ur light works)then it shouldnt be. Map sensor is quick to let you know somethings wrong. Maybe your low on fluid? I just want to make sure your not overlooking the obvious.
Old Apr 17, 2003 | 06:14 AM
Sephro's Avatar
Default Re: I have no idea... do you? (JTCdudeman)
What color is the smoke coming out the exhaust? If it is white and your having over heating problems I would guess that you've got some sort of head gasket problems.
Old Apr 17, 2003 | 07:09 AM
577HondaPrelude's Avatar
I hate to say it but it sounds alot like a cracked head gasket
Old Apr 17, 2003 | 07:49 AM
Sephro's Avatar
I've seen this stuff you can add to your coolant that will show if your burning coolant. I don't remember what it was called or how it worked. I think it might be like that stuff you can get that glows under a black light. but it would show in your exhaust if you do have a cracked head gasket. I think I saw it at an AutoZone...
delsolintegra
Nov 7, 2015 06:29 PM
Benny Bao
Oct 14, 2014 11:47 AM
BlackCivicEX
Nov 30, 2010 02:12 PM
dizzyek
May 17, 2006 09:38 AM
justinb
Jun 2, 2005 03:39 PM
