Si seats into a 88 DX ????
Old Apr 16, 2003 | 09:25 PM
Danger's Avatar
Default Si seats into a 88 DX ????
has anybody put Si seats into their 88 civic dx HB ? the dx rails has a crazy bolt pattern and only one hole on the Si rail will line up . is there any way to get them in there ? thanks
Old Apr 16, 2003 | 10:26 PM
ef9b16's Avatar
Default Re: Si seats into a 88 DX ???? (JonnyDanger)
i need to know this too, anybody know??
Old Apr 16, 2003 | 10:34 PM
thaiphob's Avatar
Nikon!!!
Default Re: Si seats into a 88 DX ???? (ef9b16)
custom fab a rail and ur set!
Old Apr 17, 2003 | 12:10 AM
Vinceg99's Avatar
Default Re: Si seats into a 88 DX ???? (thaiphob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">custom fab a rail and ur set!</TD></TR></TABLE>
Yep that would be pretty much the only way unless you found some rails that would bolt up to the seats and the stock locations?? Dont think that there out there though. Have you tried to bolt the Hatch rails onto the Si seats? You might be able to cutom fab it that way as well?
Old Apr 17, 2003 | 12:39 PM
88rexdxa6ed's Avatar
Default Re: Si seats into a 88 DX ???? (Vinceg99)
will the 90 si seats fit in a 88 crx dx?
Old Apr 17, 2003 | 01:08 PM
xsellxoutx's Avatar
Default Re: Si seats into a 88 DX ???? (88rexdx)
i have 91si seats in my 88std we just drilled through the floor and used a large grade8 nut bolt and two washers works great.
i have the entire 91 si interior seats front and rear dash gauge cluster etc.
except i have 88crx si door panels the civic ones have holes for the seatbelt
Old Apr 22, 2003 | 04:03 PM
ill45's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonnyDanger &raquo;</TD></TR><TR><TD CLASS="quote">has anybody put Si seats into their 88 civic dx HB ? the dx rails has a crazy bolt pattern and only one hole on the Si rail will line up . is there any way to get them in there ? thanks </TD></TR></TABLE>
hey jon i got them seats from my car sittin in the garage.... seats but no rails the ones that Pete stripped .
Old Apr 22, 2003 | 05:58 PM
Hunter's Avatar
Default Re: Si seats into a 88 DX ???? (ill45)
yea, i had them in my '88 hatchcrapper, just gotta weld up some brackets and bolt the rear two mounts through the floorboard
Old Apr 22, 2003 | 07:37 PM
EF Two's Avatar
Default Re: Si seats into a 88 DX ???? (Hunter)
What year SI seats will fit into a 89 Civic DX Hatchback?
Old Apr 22, 2003 | 07:43 PM
USDM 4G VTEC's Avatar
theres a few options... i dont know for sure the asnwer...
but ihave HF seats into my 90 STD
anyways .. take ur pass side off.
compare the rails..... see if the rails off ur car fits the Si seats....
if they dont.... try swaping seat pans.... if that doesnt work... then custom brackets has to be done.... chek mines..... search for crx hf seats into 90 civivc
ZC88CRX
Jul 21, 2004 10:46 PM
HGZ
Mar 29, 2004 02:10 PM
b16acrxer
Dec 11, 2003 09:45 AM
88rexdxa6ed
May 4, 2003 11:01 PM
auto-x
Nov 7, 2002 01:49 PM
