i just swapped out a 88 d16a6 from my 88 crx si to i think a 92 da16a6 1.6
Old Apr 16, 2003 | 07:58 PM
bmacy2k's Avatar
Default i just swapped out a 88 d16a6 from my 88 crx si to i think a 91 or da16a6 1.6
now when the ingnition is turned on it keeps blowing fuses and there is no power going to the fuel pump. It turns over but is not getting fuel. My question is this!!! Is the ecm different or taking more power for the 91 engine? The main engine relay is only getting power to 2 of the terminals on the relay. If someone know how to fix this please help me in anyway you can..... Thanks I checked again and the fuel pump is working b/c i bypassed it. I looked it up and the distributors are different for those years. I was also told that there is a ground by the fuel rail but I havent located it. I am gonna try changing to the old distributor and see what happens. any other suggestions are welcomed
Modified by bmacy2k at 9:44 PM 4/17/2003
Old Apr 17, 2003 | 09:09 AM
DJ_SaNdOz's Avatar
Default Re: i just swapped out a 88 d16a6 from my 88 crx si to i think a 92 da16a6 1.6 (bmacy2k)
well; for one- there was not an a6 in 92 as far as i know- so the proper engine code would help everyone figure out your problem.
Looney1
Mar 5, 2016 09:54 AM
Projekt CR-X
Sep 21, 2010 06:38 PM
swapcrx
Jul 29, 2006 06:59 PM
snoochtodanooch
11
May 22, 2005 01:03 PM
b16acrxer
Apr 7, 2004 06:51 PM
