97 driver's airbag fit in 94?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonnyDanger »</TD></TR><TR><TD CLASS="quote">it might not , 94 air bags will not plug into a 98</TD></TR></TABLE>
But the chassis didn't change until 98. I don't see any reason that they wouldn't fit. You could always check the part #'s to make absolutely sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReX »</TD></TR><TR><TD CLASS="quote">
But the chassis didn't change until 98. I don't see any reason that they wouldn't fit. You could always check the part #'s to make absolutely sure.</TD></TR></TABLE>
maybe the wiring is different as far as obd1 cars and obd2 cars
The 94 and 95 Integra airbags are not interchangeable with the 96-01 Integra airbags.
While the airbags will physically fit and bolt right in, you will not be able to plug them in - the harnesses are different.
If you want to use the 96-01 airbags, you'll need to grab the entire SRS system from a 96-01 Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djkermie »</TD></TR><TR><TD CLASS="quote">The 94 and 95 Integra airbags are not interchangeable with the 96-01 Integra airbags.
If you want to use the 96-01 airbags, you'll need to grab the entire SRS system from a 96-01 Integra.</TD></TR></TABLE>
told you so
told you so
J28S
Feb 27, 2002 11:13 AM
