Do I have a Limited Slip Differential?
I heard that if you can look through one axel hole to the other one and see through it than you have LSD. Well I can see through it minus this sort of metal pole shaped thing in the middle. Does this mean I have LSD? It's a ZC Tranny and I've heard that a rare few of them did have LSD so I was just wondering.
thats the shaft the spider gears are located on with a NON LSD transmission. You don't has a LSD i hate to say. another way to prove it. jack up the car both wheels off the ground. Put it in gear with engine off. Rotate one wheel, I will be you the other wheel turns the opposite direction.
"..girl if you were a piece of paper than i would be your ink, if you were a piece of doo doo than i would be your stink.....i'm a remote control and you're my favorite channel, girl i dig you like a mole, i wanna hump you like a camel.."
-Mountain Brothers (love poetry)
im sorry, i have seen alot of peoples quotes, and this one has to be the only one which i thought was the both the corniest and crappiest...
just fyi- CHANGE IT
just fyi- CHANGE IT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Winjury »</TD></TR><TR><TD CLASS="quote">"..girl if you were a piece of paper than i would be your ink, if you were a piece of doo doo than i would be your stink.....i'm a remote control and you're my favorite channel, girl i dig you like a mole, i wanna hump you like a camel.."
just fyi- CHANGE IT</TD></TR></TABLE>
wtf did i just read?
why the hell did you bump this 3 year old post for that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro »</TD></TR><TR><TD CLASS="quote">
x2, Que le ***?
</TD></TR></TABLE>x2, Que le ***?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude »</TD></TR><TR><TD CLASS="quote">thats the shaft the spider gears are located on with a NON LSD transmission. You don't has a LSD i hate to say. another way to prove it. jack up the car both wheels off the ground. Put it in gear with engine off. Rotate one wheel, I will be you the other wheel turns the opposite direction.</TD></TR></TABLE>
That is called a pinion shaft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">
x2, Que le ***?</TD></TR></TABLE>
x3 Que le ***!?
x3 Que le ***!?
CRX A4
Apr 5, 2003 04:04 AM
