will dx axles work with a si tranny?
Old Apr 16, 2003 | 07:17 PM
88rexdxa6ed's Avatar
Default will dx axles work with a si tranny?
i'm about to put a 91 si motor and tranny in my 88dx will the stock dx axles fit?
Old Apr 16, 2003 | 07:24 PM
FourthGenHatch's Avatar
Default Re: will dx axles work with a si tranny? (88rexdx)
Hmmm, the outer splines should be both 26 since Si and DX was the same. However I heard that the 88s had a different number of inner splines than the 89-91, I know that 88 had 21 clutch splines, and 89-91 had 20, so I wonder if the 88 had different number of inner axels splines. But I'm not really sure.
Old Apr 16, 2003 | 07:53 PM
Jockobo's Avatar
Default Re: will dx axles work with a si tranny? (FourthGenHatch)
it should fit becuase i had the same setup
Old Apr 16, 2003 | 08:05 PM
Default Re: will dx axles work with a si tranny? (Jockobo)
Ok maybe the inner splines were all the same.
Old Apr 16, 2003 | 10:06 PM
Louie B.'s Avatar
that's the input shaft that has a different # of splines.
yes, you will be fine with dx axles on your si tranny.
Old Apr 17, 2003 | 01:16 AM
DA6GSR's Avatar
Default Re: will dx axles work with a si tranny? (thumpu77)
I thought in order to go to the SI tranny you had to replace the axles because on the DX youhave no intermediate shaft. They have one long and one short axle. Or is that only on the 92-95 SI model trannies?
Old Apr 17, 2003 | 04:18 AM
tpr's Avatar
tpr
Yes, the DX axles will work in the SI gear box 88-91 for sure.
Old Apr 17, 2003 | 04:32 AM
DA6GSR's Avatar
Default Re: will dx axles work with a si tranny? (tpr)
Lookie there I learn all the time
Old Apr 17, 2003 | 04:51 AM
USDM 4G VTEC's Avatar
yes u can use ur stock axles on the SI tranny.... all 88-91 have the same input shaft (the end that goes into the tranny) just the outer one (that goes into knucles ) are diff from STD to the DX and si's(dx+si same )
Old Apr 17, 2003 | 05:02 AM
virginia_dude's Avatar
yes they will work, I did that on my '89 DX hatch when I did my ZC Swap and ran an Si box , that was before I moved on to the ZC trans with integra axels. But yes it does work. Been there, done that.
Old Apr 17, 2003 | 12:36 PM
Default Re: will dx axles work with a si tranny? (virginia_dude)
thanks, now i can swap my motor and tranny from my si to my 88 dx
91sihatchback
Jul 12, 2004 07:56 AM
projectcrx
Mar 26, 2003 09:57 PM
shortyz
Aug 13, 2002 11:48 AM
zcivicz
30
Apr 15, 2002 02:29 PM
charjacq
Apr 11, 2002 04:17 PM
