Those with KYB AGX
Old Apr 16, 2003 | 06:16 PM
Ronin Integra8's Avatar
Default Those with KYB AGX
I've had my KYB AGX's on my car for almost 4 months. I first rode on them at setting 1, then moved it to setting 2 like a week later. Then today I moved it to setting 3. What should it be on? I heard 1 and 2 are like stock ride, 3 and 4 are stiffer, but why would you do one over the other? What should I have mine at?
Old Apr 16, 2003 | 07:50 PM
badnan's Avatar
Default Re: Those with KYB AGX (Ronin Integra8)
for daily driving use i set them to 1/1. if i feel like going out for a spirited drive i do 2/3 or 3/4. when i go autox i set them to 3/4.
1/1 is very smooth and comfortablbe, why have a rough ride when i dont need the full stiffness? thats the reason i got adjustables, so i could adjust the stifness when it was needed.
Old Apr 16, 2003 | 10:28 PM
seanb18c1's Avatar
Default Re: Those with KYB AGX (badnan)
1 in front
2 in rear
stiffest i go on the street
track is different
Old Apr 16, 2003 | 10:35 PM
Brasspremier's Avatar
Default Re: Those with KYB AGX (seanb18c1)
all 4's for me. doesnt bother me and when i turn settings down, doesnt seem too much different when driving normally. maybe its because of the climate
Old Apr 16, 2003 | 10:46 PM
SMZ GSR's Avatar
Default Re: Those with KYB AGX (Brasspremier)
3/4 all the time. drive a beater most of the time so the stiff setting doesn't bother me. plus i've never had any complaints from passangers
Old Apr 17, 2003 | 12:22 AM
95integrags-r's Avatar
Default Re: Those with KYB AGX (SMZ GSR)
mine are always on 4. no one says n e thing and It seems to be easier to go over speed bumps without scraping.
Old Apr 17, 2003 | 12:25 AM
turbospool's Avatar
Default Re: Those with KYB AGX (95integrags-r)
on both shocks at the stiffest settings, which would be stiffer, Tokico Illuminas or KYB AGX?
Old Apr 17, 2003 | 05:06 AM
dip-set's Avatar
Default Re: Those with KYB AGX (turbospool)
quick qeustion...why stiffer for the real all the time...i always see...1/2 or 2/3 or 3/4..what would be the effect of the setting all even..1/1 , 2/2 , 3/3 , 4/4..or front stiffer...2/1 , 3/2 , 4/3...thanks..
Old Apr 17, 2003 | 07:49 AM
JDubya's Avatar
Default Re: Those with KYB AGX (teg-your-it)
A stiffer setting in the rear just helps reduce the under steer. Someone correct me if i'm wrong...
Old Apr 17, 2003 | 09:49 AM
Seedc2's Avatar
Default Re: Those with KYB AGX (ALL MOTOR LS)
^ wanna know if thats true
Old Apr 17, 2003 | 11:07 AM
SMZ GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS &raquo;</TD></TR><TR><TD CLASS="quote">A stiffer setting in the rear just helps reduce the under steer. Someone correct me if i'm wrong...</TD></TR></TABLE>
what i've been taught.
Old Apr 17, 2003 | 11:16 AM
Malice's Avatar
New User
i ride 3's all around
Old Apr 17, 2003 | 11:30 PM
turbospool's Avatar
Default Re: Those with KYB AGX (MaliceGSR)
so does anybody kno if the illuminas are stiffer or the agx, both on the stiffest setting.
Old Apr 18, 2003 | 05:31 AM
revvhappy's Avatar
1/1 for daily driving
3/3 for agressive
Someone may be right about the 'stiffer' rear helping cars with understeer prob. I have a Susp Tech rear anti-sway and get a bit of oversteer, and the guys at the race forum recommended I run softer setting on the rear to help.
I'll try 3/2 or 4/3 next time and let you know.
Old Apr 18, 2003 | 09:03 AM
red97gsr's Avatar
I am either 4/4 or 3/4 all the time. It is not that stiff. It feels mild compared to other "stiff" cars I have rode in.
Old Apr 18, 2003 | 10:27 AM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: Those with KYB AGX (red97gsr)
I run 3/4 with sportline springs
Old Apr 18, 2003 | 11:28 AM
GSR-REX's Avatar
New User
For daily driving I keep 'em at 2 all around. If I'm going for a "drive", I'll set them at 3/4.
4/4 makes my teeth rattle after a while...and I can't afford to keep getting my fillings put back in!
Old Apr 20, 2003 | 07:22 PM
Honda Hick's Avatar
I used 1 in front and 2 in back to keep my ***-end planted better. The back would seem to roll more I guess becuase its higher and it felt alot tighter on 2.
kuja396
Suspension & Brakes
Aug 24, 2008 08:36 AM
darklotus958
Suspension & Brakes
Jan 25, 2008 09:01 AM
LOWLIFEHATCH
Apr 5, 2004 02:40 PM
akeldama
Dec 30, 2002 09:49 PM
Duck Sauce
Jan 27, 2002 03:29 PM
