How to remove axles w/ out taking out the ball joint???
Old Apr 16, 2003 | 06:07 PM
Blaze45's Avatar
Brrraaaap!
Default How to remove axles w/ out taking out the ball joint???
I have searched and found nothing. I know there is a way to remove axles and not have to break that lower ball joint. Anyone know how? On my cousins 85 REX we removed the front shock/spring assm. and then the hub just went flimsy and we moved it and pulled the axles out the tranny. Is this how? Just curious if its the same on the 2nd gen rexs.
tia
Blaze
Old Apr 16, 2003 | 06:10 PM
poison's Avatar
Default Re: How to remove axles w/ out taking out the ball joint??? (Blaze45)
You have to pop the top or bottom ball joint. Reason for this is because the hub is fastened and holds the axle in and there is not enough room to pop the CV joint out of the tranny.
Just pop the joint and pull her out.
Old Apr 16, 2003 | 06:23 PM
StorminMatt's Avatar
You CAN remove the axle without popping the lower ball joint. All you need to do is unbolt the radius rod from the lower control arm, unbolt the shock (which you need to do anyway), and unbolt the lower control arm from the rear crossmember.
Old Apr 16, 2003 | 07:15 PM
Blaze45's Avatar
Brrraaaap!
Default Re: How to remove axles w/ out taking out the ball joint??? (StorminMatt)
Ah yes thanks storminmatt!
Blaze
Old Apr 16, 2003 | 07:53 PM
tilt's Avatar
yep, ive done it that way before... it's just 2-3 bolts and it swings around.
Pellegrino_10
Jul 17, 2014 05:48 PM
sanman000719
Jul 7, 2011 07:47 PM
B18CYAAA
Oct 25, 2006 02:29 PM
See Are X
Feb 2, 2003 07:00 PM
Leo95SE
Jul 15, 2001 04:16 PM
