Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tape used to cover headlights or parts of the car you dont want to get chips on...
Old Apr 16, 2003 | 05:13 PM
1 speedstar's Avatar
Default tape used to cover headlights or parts of the car you dont want to get chips on...
my car just got sprayed and i'm planning on taking a trip very soon. I've seen people use some sort of tape or sticker on the front end of their car to not get paint chips on the front end? I've seen it most from people that are road racing or the like. If anyone knows where i can get some, or if its just vinyl sticker i'd really appreciate it. thanks
Old Apr 16, 2003 | 05:22 PM
MaddMatt's Avatar
Default Re: tape used to cover headlights or parts of the car you dont want to get chips on... (1 speedstar)
You might be refering to painters tape. It's low tack, and I get it at Lowes or Home Depot.
I generally get the "Shultz Blue" color. It gets people's attention when I want a passing signal...
Old Apr 16, 2003 | 05:28 PM
asmallsol's Avatar
Default Re: tape used to cover headlights or parts of the car you dont want to get chips on... (MaddMatt)
There is also this more permant way to solve this issue. 3m makes a product that is designed to replace the Car Bra. What it is is a special thin plastic film that they put on the first few inches of your hood. It is so much better then a car bra because it does not collect water which then rusts and oxidizes your paint, doesn't mask any other areas up from the sun which on a car bra results in tan lines for your car. 3m also has these for your headlights which prodect against rocks.
Old Apr 16, 2003 | 06:11 PM
CRX Lee's Avatar
The clear tape that you refer to is called "helicopter tape" as I think it is used on the leading edge of 'copter rotor blades. Quite common on formula cars, etc. to cut down knicks from impacts as they can casue not only damage but parasitic aero drag. I know aero drag from paint chips sounds silly but as a kid I crewed at a sailplane national championships and it was important to not only get the bugs off the sleek gliders but it was my first experience with a chamois as even dried water spots could cause some amount of aero drag that could effect performance.
I know Truechoice sell helicopter tape so I'm betting Pegasus and other racer supply companies do as well. I've not used the stuff myself so I can't contribute on price, longevity or ease of installation.
Old Apr 16, 2003 | 06:55 PM
phat-S's Avatar
Default Re: tape used to cover headlights or parts of the car you dont want to get chips on... (CRX Lee)
You might want to look into Laminex (think that is the spelling) - its a protective clear coating that IIRC is removable.
Old Apr 16, 2003 | 07:07 PM
siisgood00's Avatar
New User
Default Re: tape used to cover headlights or parts of the car you dont want to get chips on... (phat-S)
That helicopter tape is so damn expensive its almost funny. Masking tape for me works fine.
Old Apr 16, 2003 | 08:19 PM
johng's Avatar
3M Clear Bra. A friend of mine just had it installed on his new 330ci. You can just barely see the line on the front 1/4 of the hood. Good stuff for a new paint job.
Old Apr 16, 2003 | 09:25 PM
Default Re: tape used to cover headlights or parts of the car you dont want to get chips on... (johng)
thanks for the many responses guys, i appreciate it. I think I'll be looking into the painters tape and also the 3M clear bra. thanks again!
Old Apr 17, 2003 | 05:28 AM
John's Avatar
New User
Make sure you avoid the protective film that tends to yellow with age, I don't remember exactly which one it is. There's several different companies that make the protective film sheets, the key is finding an experienced installed who'll do a clean job.
Old Apr 17, 2003 | 05:33 AM
Track rat's Avatar
Default Re: tape used to cover headlights or parts of the car you dont want to get chips on... (DunReit)
3m is good stuff, but a cheap "weekend only" solution is clear shelf paper from Home Depot. It is clear mylar on a 24" wide roll with a low tack adhesive that comes off easily.
Old Apr 17, 2003 | 11:29 AM
Default Re: tape used to cover headlights or parts of the car you dont want to get chips on... (Track rat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">3m is good stuff, but a cheap "weekend only" solution is clear shelf paper from Home Depot. It is clear mylar on a 24" wide roll with a low tack adhesive that comes off easily. </TD></TR></TABLE>
that is exactly what i'm looking for. thanks, ill be looking for that today
Old Apr 17, 2003 | 12:25 PM
Lt. Dan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaddMatt &raquo;</TD></TR><TR><TD CLASS="quote">You might be refering to painters tape. It's low tack, and I get it at Lowes or Home Depot.
I generally get the "Shultz Blue" color. It gets people's attention when I want a passing signal...</TD></TR></TABLE>
"Low Tack".... HAHAAAA!!! Just ask Crack Monkey about how "low tack" that stuff was coming off of his Caprice.... hehe...
Dan
Old Apr 17, 2003 | 12:26 PM
.RJ's Avatar
.RJ
Default Re: tape used to cover headlights or parts of the car you dont want to get chips on... (Lt. Dan)
Dan, i dont think you're supposed to apply it to a rusty bucket
Old Apr 17, 2003 | 12:44 PM
Lt. Dan's Avatar
Default Re: tape used to cover headlights or parts of the car you dont want to get chips on... (.RJ)
Someone should've told Al that....
Dan
Old Apr 21, 2003 | 06:25 AM
GBRacing's Avatar
Man, Phat-S beat me to it. I have the stuff on my entire front end, top and front of my bumper, on my hood 8 inches up, small strip on my rear bumper, tail lights, head lights and practically covering my entire cage. The stuff is great and stays nice and shinny. Check them out http://www.lamin-x.com
yonidf99
Lighting
Oct 8, 2013 12:32 PM
charliegotswag
Lighting
12
May 27, 2009 06:34 PM
turboman
Mar 29, 2005 09:45 AM
jdmgsr_ej1
Nov 14, 2004 07:46 AM
guttedsilvercrx
Dec 10, 2003 07:20 PM
