optional tire sizes for 14" rims
didnt know where else to post this but i have a 95 ex coupe and i think the stock tires are 185/60-14 according to tirerack.com, doesnt seem right though. But anyway is there any other sizes i can throw on there? maybe somthin a little wider? thanks...
Dunlop 195/55-14's would work. Not many other options unless you go to a larger overall diamter- which will adversely affect your acceleration.
How wide are your rims? 5.5, 6 inches. Find out then check the tire rack's rim size/wheel size spread sheet. Also Wider is Better most of the time, but if you deviate too far you sacrifice side wall effectiveness.
If I were you I'd concentrate on what kind of tire you buy.
195/55 or 195/60 may be a good solution.
205s might be on the edge depending on rim width.
-2 cents
-2 cents
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emwavey »</TD></TR><TR><TD CLASS="quote">205s might be on the edge depending on rim width.
Hrmm, I run 225/50-14 Toyo RA1s Full Tread on my Stock Steelies (5.5" rims afaik)
dacrazy
Jun 24, 2005 01:50 PM
