Need Help!!
Old Apr 16, 2003 | 01:29 PM
maxrpm's Avatar
Default Need Help!!
I have a ls/vtec engine in a integra. The problem is that the car seems slow. I took it to the track and im running low 15s. I need some suggestion on what can be the problem. The setup is 11:1 piston, port and polished head with new springs and retainers, 90mm rods, usinig gsr head and 2.0 liters. It might be me driving also but i had my friend drive and he gets low 15s also.
Old Apr 16, 2003 | 04:16 PM
delslow94's Avatar
Default Re: Need Help!! (maxrpm)
what tranny...what ecu...any fuel upgrades....check your plugs and see what they look like. if you have the ls tranny youll be slow no matter
Old Apr 16, 2003 | 07:58 PM
maxrpm's Avatar
the tranny is a gsr the ecu is a skunk 2 and no fuel upgrades. Would it be my timing causing the car to lose horse power.
Old Apr 17, 2003 | 06:31 AM
vadim's Avatar
Default Re: (maxrpm)
the timeing on the distributor is off you need to advace the timeing on the distributor.
Old Apr 17, 2003 | 08:14 AM
1bad-eg's Avatar
Check your timing but be careful, you have high compression. Also check your valve lash. If the lash is too tight or too loose it can seriously kill power.
Old Apr 17, 2003 | 10:57 AM
maxrpm's Avatar
I readjusted my valves and I have this problem lining up my timing marks. The intake cam gear is one or two tooth retard. Does any know what other ls /vtec runs at the track?
Old Apr 17, 2003 | 12:29 PM
fukaintmuven's Avatar
same problem here.... just way more $$ dumped and wasted to my motor..
Old Apr 21, 2003 | 05:58 AM
vadim's Avatar
Default Re: (fukaintmuven)
13.3
Old Apr 21, 2003 | 07:42 AM
IN VTEC's Avatar
What kind of numbers have you put out on the dyno?
Old Apr 21, 2003 | 09:41 AM
All Motor Rex's Avatar
Default Re: Need Help!! (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">What kind of numbers have you put out on the dyno?</TD></TR></TABLE>
Yea, what he said. Has the car been tuned yet? If not, find a good tuner and head to the dyno!
jdmhonda31558
Dec 18, 2010 05:56 PM
projectef
17
Dec 10, 2008 05:06 PM
bebe101
Nov 21, 2008 05:32 PM
rotascircuit
Mar 22, 2008 11:29 PM
piggypen
Feb 22, 2005 11:11 PM
