Pr3 ECU needs 2 o2 sensors?
Old Apr 16, 2003 | 01:15 PM
Darin D.'s Avatar
Default Pr3 ECU needs 2 o2 sensors?
I swapped a gsr motor into a friends 91 crx si. we have a chipped pr3 ecu in it and it runs really really rich and just generally shitty. I dont have any o2 sensors plugged in. I was told that the pr3s require 2 o2 sensors to run properly, 1 in the front of the header and 1 at the collector.
Is there any way to get around this and run without an o2 sensor, or just run with 1 in the collector? because i really dont want to drill a hole and weld a bung in the front of my spoon header.
Thanks.
Darin
Old Apr 16, 2003 | 01:39 PM
slowpokesi's Avatar
Default Re: Pr3 ECU needs 2 o2 sensors? (Willis)
okay there are like 4 of these threads going on, why make another one,
whoever told u that was wrong, the pr3 requires 2 o2 sensors, on the upper section of the manifold, one reads cylinder 4 and 3 and the other reads 2 and 1
look in the picture, u will see the 2 o2 sensors, one is tucked behind but u can make it out.
Old Apr 16, 2003 | 02:03 PM
2sloCrx's Avatar
Default Re: Pr3 ECU needs 2 o2 sensors? (slowpokesi)
hey i'm guessin thats ur motor! looks SWEET!
Old Apr 16, 2003 | 02:23 PM
Darin D.'s Avatar
I think i found a solution to the problem. I found a guy locally who has a mugen chip for a pr3, he says with the mugen chip i only need 1 o2 sensor in the collector and it will run perfect.
Does anyone know if this is true about the mugen chip?
Thanks.
Darin
Old Apr 16, 2003 | 02:38 PM
Fobtions's Avatar
with the mugen program you pretty much don't need any o2 sensors.
Old Apr 16, 2003 | 05:22 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Pr3 ECU needs 2 o2 sensors? (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">with the mugen program you pretty much don't need any o2 sensors. </TD></TR></TABLE>
That's not entirely correct.
I have a PR3 ECU with the Mugen Chip.
It DID throw an O2 sensor code when I drove without the O2 sensor for a day.
About you being able to use 1 O2 sensor, that is correct.
I have 1 O2 sensor (one wire unheated) located near the catalytic converter.
I spliced the wire and sent the signal to both O2 sensor ports on the ECU (C8 and C16). It works fine.
Modified by Spaceballs the lunch box at 5:42 PM 4/17/2003
Old Apr 16, 2003 | 05:30 PM
primoEF's Avatar
Default Re: Pr3 ECU needs 2 o2 sensors? (Spaceballs the lunch box)
here is a pic of mine on the DC header
Old Apr 16, 2003 | 07:59 PM
ihaterice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spaceballs the lunch box &raquo;</TD></TR><TR><TD CLASS="quote">
i have a PR3 ECU with the Mugen Chip.
I have 1 O2 sensor (one wire unheated) locate near the catalytic converter.
I spliced the wire and sent the signal to bot O2 sensor ports on the ECU (C1 and C16). It works fine.</TD></TR></TABLE>
whats up george this is james from titan, darin is working on my car trying to get it running..if you can give us a call tomorrow at work - 407-277-8423, we have some questions we want to run by you and you might be able to help us troubleshoot them the best.
james
Old Apr 16, 2003 | 10:53 PM
Fobtions's Avatar
Default Re: Pr3 ECU needs 2 o2 sensors? (ihaterice)
well there is more than one mugen chip, there are probably two-three variants. i have a genuine mugen pr3 and i have no o2's hooked up. a number of the chip copies ive seen do look for it.
rexbooming
May 20, 2012 02:43 PM
beerguy6903
Mar 6, 2009 04:23 PM
domino
Sep 29, 2005 07:47 AM
shadowstylz
13
Sep 15, 2003 10:33 PM
