Big Block EP - K24 Frankenstein (Dyno results and Pics)
Old Apr 16, 2003 | 12:33 PM
B18CXr's Avatar
Default Big Block EP - K24 Frankenstein (Dyno results and Pics)
http://www.p1auto.com/bigblockep/ep.htm
Old Apr 16, 2003 | 12:34 PM
ep3minivan's Avatar
Default Re: Big Block EP - K24 Frankenstein (B18CXr)
It's not working for me right now.
D's Avatar
D
damn, first one on the block.
Old Apr 16, 2003 | 01:01 PM
RStoR's Avatar
Default Re: Big Block EP - K24 Frankenstein (D)
looks good above 5300
Old Apr 16, 2003 | 02:00 PM
fuzzynutz's Avatar
Default Re: Big Block EP - K24 Frankenstein (RStoR)
cool deal looks good jack we should have our 2.4 hatch on the dyno this weekend.
Old Apr 16, 2003 | 02:06 PM
ep3minivan's Avatar
Default Re: Big Block EP - K24 Frankenstein (fuzzynutz)
Old Apr 16, 2003 | 04:57 PM
anjapower's Avatar
Default Re: Big Block EP - K24 Frankenstein (ep3minivan)
maybe it's just because I don't know any better, but that dyno is really hard to comprehend.
Old Apr 16, 2003 | 05:46 PM
DBurke's Avatar
Those are some good looking gains. How much power did it really make though.
Old Apr 16, 2003 | 05:49 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Big Block EP - K24 Frankenstein (anjapower)
The dyno just shows the increase in power over the K20a3 right?
Whats the setup? K24/20a hybrid?
Old Apr 16, 2003 | 05:50 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: Big Block EP - K24 Frankenstein (FrostyDC4)
more pics...plz.....thanks...
Old Apr 16, 2003 | 05:58 PM
D ROC DC5's Avatar
It was cool experiencing the "frankenstein" first hand at the expo! The bus is gonna be nuts when you get it all sorted out. I can't wait until you work the magic on my toda cams next month!
BTW- some stiff bushings wouldn't hurt, she was dancin' somethin' fierce braking hard into turn one!
Old Apr 16, 2003 | 07:24 PM
chad's Avatar
Moderator
that mini van rolled alot of hype R's at the 3rd itr expo!!!
Old Apr 16, 2003 | 08:23 PM
PhxK20a3's Avatar
Default Re: Big Block EP - K24 Frankenstein (chad)
um,sorry but i saw some lines on the dyno and thats about it.Care to share some before/after #s?????
Old Apr 16, 2003 | 09:34 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anjapower &raquo;</TD></TR><TR><TD CLASS="quote">maybe it's just because I don't know any better, but that dyno is really hard to comprehend.</TD></TR></TABLE>
yup, its like taking graph paper, drawing a few lines with arbitrary numbers on the sides and saying how much more power u made....
Old Apr 16, 2003 | 11:53 PM
Mike M's Avatar
Founding Member
Default Re: Big Block EP - K24 Frankenstein (There is no sp00n!)
Dude where's the Block Code {Mike gets another punch in the arm by Jack}
hehe Just messin with ya Jack
Nice Job on being the 1st I never did get that ride out on the track so hold a spot for me at the next event
Old Apr 17, 2003 | 03:35 AM
Johnny Tran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by There is no sp00n! &raquo;</TD></TR><TR><TD CLASS="quote">
yup, its like taking graph paper, drawing a few lines with arbitrary numbers on the sides and saying how much more power u made.... </TD></TR></TABLE>
its not at all hard to comprehend when you understand what you are looking at. That is a function run on a Mustang Dyno. Imagine that you made a "baseline run" and the dyno will record this "chart" as zero on the x axis. Therfore, what you are seeing is only the gains relative to the "baseline run"...if there were losses, they would be shown as negative readings on the coordinate system...just like your geometry class. Hope that clears it up a bit.
Nick
Old Apr 17, 2003 | 05:47 AM
.RJ's Avatar
.RJ
Default Re: Big Block EP - K24 Frankenstein (Johnny Tran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Tran &raquo;</TD></TR><TR><TD CLASS="quote">its not at all hard to comprehend when you understand what you are looking at. That is a function run on a Mustang Dyno. Imagine that you made a "baseline run" and the dyno will record this "chart" as zero on the x axis. Therfore, what you are seeing is only the gains relative to the "baseline run"...if there were losses, they would be shown as negative readings on the coordinate system...just like your geometry class. Hope that clears it up a bit.
Nick</TD></TR></TABLE>
Please dont ask the n00bs to think
Old Apr 17, 2003 | 07:15 AM
The Crow's Avatar
Cool!! Any problems???
Old Apr 17, 2003 | 08:15 AM
YumVTEC's Avatar
Default Re: Big Block EP - K24 Frankenstein (The End)
so the stock ep3 si head with a stock k24 crv bottom end (pistons, rods, etc... untouched)??
those are good numbers. i wonder what a dc5-r head on a k24 block with high comp pistons would look like. woo...
Old Apr 17, 2003 | 08:38 AM
anjapower's Avatar
Default Re: Big Block EP - K24 Frankenstein (YumVTEC)
No its a rsx-s head on a crv block.
Mike M: even though I don't have a K24 Frankenstein motor, I can probably give you a ride in mine
Old Apr 17, 2003 | 09:05 AM
ATYPR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC &raquo;</TD></TR><TR><TD CLASS="quote">so the stock ep3 si head with a stock k24 crv bottom end (pistons, rods, etc... untouched)??
those are good numbers. i wonder what a dc5-r head on a k24 block with high comp pistons would look like. woo...</TD></TR></TABLE>
The CRV head has bigger ports than the Si. Check these pics out!
Warning!! No 56K!!!
https://honda-tech.com/zerothread?id=474628
Old Apr 17, 2003 | 12:53 PM
Default Re: Big Block EP - K24 Frankenstein (FUCATYPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUCATYPR &raquo;</TD></TR><TR><TD CLASS="quote">The CRV head has bigger ports than the Si. Check these pics out!</TD></TR></TABLE>
id rather have "b3tekk" on the exhaust cam....crv does not, P1 bus does
Big Si Guy's Avatar
ummm...
who cares what it made vs. a k20a3...
that's apples to oranges.
how bout vs. a k20a2?
Old Apr 17, 2003 | 01:31 PM
wHOAlly's Avatar
ahh, now it makes sense, what the caption read wasnt clear
Old Apr 17, 2003 | 03:48 PM
B18CXr's Avatar
Default Re: (Big Si Guy)
First K24 powered EP in NC.
LOL, sure. whatever
site updated just for you.
