What lugs size do I need ofr RH CP035 on ITR?
Old Apr 16, 2003 | 10:55 AM
Nuts's Avatar
Default What lugs size do I need ofr RH CP035 on ITR?
as title said..
thanks,
CS
Old Apr 16, 2003 | 07:48 PM
Nuts's Avatar
Default Re: What lugs size do I need ofr RH CP035 on ITR? (CS)
anyone?
thanks,
CS
Old Apr 16, 2003 | 08:15 PM
seek167's Avatar
not sure what your asking 5x114.3
Old Apr 16, 2003 | 08:25 PM
Nuts's Avatar
Default Re: What lugs size do I need ofr RH CP035 on ITR? (seek167)
as in
size: 12mm * 1.25
dimensions: 19.0mm Hex * 34.0mm height
will fit or do I need some other size/dimensions?
thanks,
CS
Old Apr 16, 2003 | 08:29 PM
py1188's Avatar
You need a tapered lug as opposed to an acorn lug
Not sure about the dimensions, although they look correct
Old Apr 16, 2003 | 08:37 PM
Padawan's Avatar
Darth ModerVader
You'll need 12mm x 1.5, conical (tapered) seat lugs.
Old Apr 16, 2003 | 08:45 PM
Nuts's Avatar
Default Re: What lugs size do I need ofr RH CP035 on ITR? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">You'll need 12mm x 1.5, conical (tapered) seat lugs. </TD></TR></TABLE>
thanks, but what's the different between 12mm x 1.5 VS 12mm x 1.25? what's the potential problem with 1.25?
CS
Old Apr 16, 2003 | 08:47 PM
Mario's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CS &raquo;</TD></TR><TR><TD CLASS="quote">
CS</TD></TR></TABLE>
Problem is...
...they wont fit.
C_H_A_D
Feb 20, 2006 01:42 PM
ocdcivic
Jan 16, 2005 05:02 PM
b16 matt
Oct 7, 2003 12:28 PM
NeoGSR
Jun 3, 2003 02:40 PM
Suzukablue
Apr 23, 2003 09:02 PM
