Your wish list!
Old Jun 26, 2001 | 09:09 PM
raene's Avatar
Default Your wish list!
Alright, everyone tell what you've got and what you want. Pictures aren't necessary; we believe you actually have it . And only list things you could actually GET - I know we all WANT a T66 turbo or a 200-shot of N20, but for most of us, nuh-uh, not happening.
What I have:JDM B16A CRX, K&N drop-in filter, B&M fuel pressure gauge and regulator, Autometer carbon fiber air/fuel meter, a dual gauge pod, some fancy-lookin' shift pedals, dual 10" subwoofers in a bandpass box running 40 watts to each sub, four two-way crossovers with 4 3/4" directional silk tweeters and 4 6" woofers mounted in the stock locations.
What I want (and eventually will get): An adjustable shift linkage, a Skunk2 adjustable camber kit, some lightweight 5 or 6-spoke 16" wheels wrapped with Dunlop SP8000 Extreme tires, a set of adjustable Skunk2 cam gears, an Autometer carbon fiber oil pressure gauge, a shorty intake (probably K&N), an Edelbrock header (they've gotta make them for Civics as well as Integras!), Thermal R&D exhaust, and a 6-point rollcage. Oh yeah, and a self-done paintjob & bodywork session.
Old Jun 26, 2001 | 09:44 PM
pagong's Avatar
Default Re: Your wish list! (raeneshadow)
i like this
what i HAVE: JDM B16, crower rods, SRP 9:1 pistons, o-ringed block, balanced and blueprinted engine,revhard manifold, T3/TO4E stg. 3 turbine .54 a/r, Tial 35 mm wastegate, SX regulator, MSD fuel pump, HKS bov, Spearco GTR sized intercooler (29x12x2 1/2), ground controls, tokico 5 way illuminas, ww rs kit, GSR rims, GSR front brakes, place racing crossmember, autometer tach, apex boost gauge, momo steering wheel, neuspeed short shifter and tower bar, MSD 6a and blaster coil w/ pro cap. And of course cant forget the all important.....AUTOLOCK yeah!
stuff i WANT: Spoon 15x7 rims,Hondata stg 4 w/ boost (soon to be ordered) rear disk brakes, sparco seats, roll cage (soon), nice set of slicks and maybe a set of Bogarts and actually thats about it...maybe a new paint job.
Old Jun 26, 2001 | 09:49 PM
raene's Avatar
Default Re: Your wish list! (pagong)
Geeez man, my jaw dropped just reading all that stuff... yikes. What do you run in the 1/4?
And... how much do those GSR rims weigh? I'd like a set, but only if they're worth it .
Old Jun 26, 2001 | 11:00 PM
Redline130's Avatar
What I got: B18A, DC 4-2-1 headers, WeaponR intake, Thermal R&D cat-back, B&M FPR, MSD 6A, UR pulley, test pipe, CM stage 3 clutch, Tokico (non-adjustables) in the front, KYB AGXs in the rear, Skunk2 coilovers, and SSR Type-X's.
What I want:BOOST!!!
cyber13
http://cyber13.speedhawaii.net
http://redline808.speedhawaii.net
Old Jun 27, 2001 | 06:23 AM
91sifreak's Avatar
New User
Well here's what I now have running...
B16a in a 91Si, HCP mount kits, used the stock intake tubing with a k&n at the end, a set of 15" tuners with the Kumho tires, Jun stage 2 cams
what I want:
ITR valves, springs, TI retainers, VAFC, spoon cam gears, Skunk2 intake manifold, 70mm throttle body, JDM ITR header, and a set of spoon 15" black powder coated rims.
Old Jun 27, 2001 | 07:20 AM
eg6ajk's Avatar
Default Re: Your wish list! (91sifreak)
Current setup:
92 EG6 chassis, JDM b16a, Y21 tranny, Tanabe header, HKS filter, Z-Speed cam gears, Toda flywheel, Excedy 3-puck with HD pressure plate, JDM Spoon ecu, ITR sway bars, Tein HAs, Cusco strut barsbars, SiR-G front seats, VTi gauge cluster, GSR complete brakes/suspension, EG6 SiR rear wing, 96 specsR front lip, PR 15x6.5" (12lbs each) on 195/50R15(summer), 97 mesh GSRs 15x6" in bronze(winter), 5zigen fireball (summer) and 5zigen cannonball (winter) mufflers.....
what I want is:
JDM 98+ SpecR Tranny 4.785 & LSD
Toda Spec B cams and complete valve train
1.8l gsr/ITR block with my P30 pistons
and my long gone AE86.....i want it back but this time with 4age 20v, and some suspension work....
Old Jun 27, 2001 | 11:47 AM
TypeR0207's Avatar
Default Re: Your wish list! (eg6ajk)
What I've got:
'90 STD hatch, nothing on it .....
Cheapy front and rear strut tower bars sitting in a box.
A polished B16 valve cover on the way, cut for cam gears.
What I'll get (by X-mas bonus time .... hehehehehe, well, maybe not all of it):
B16A swap, ECU JDMHondaparts chipped of course, HASport mounts and linkage, RAxles, Hytech header, DAC or AEM short ram, Crower valvetrain, Crower cams, Endyn rods and 11.6:1 pistons, if I can't find it, a custom 2.5" exhaust, 310 cc injectors, VTEC controller, yadda yadda yadda.
Plan on getting to 200 whp all motor eventually .....
Old Jun 27, 2001 | 06:31 PM
Tbone's Avatar
Default Re: Your wish list! (TypeR0207)
My set up
90 hatchback, Hasport mounts, 2001 b18c5 shortblock with spoon jdm itr pistons,2000 itr head, mugen head gasket, 11.4CR, Toda spec b cams, toda cam gears, portflow inners and itr outer springs, skunk intake manifold, outlaw enginerring phenolic spacer, rc 64mm throttlebody,moroso (endyn style)oil catch can, str fuel rail, b&m fpr, unorthadox single rib pully, kooks 4-1 header(smsp on order), msd 6al, blaster coil, vafc, greddy a/f guage, clutchmasters stage 4 clutch and flywheel, ss brake lines, stillen rotors and pads, kyb adjustables with integra skunk coilovers, front and rear strut bars, energy suspension bushings(what a pain in the a$$), str dipstick, I think I got some more but I cant think,
Isnt this great info for thieves.
What I want
I want 16 new valves because last weekend my timing belt shreded some teeth and bent them all. Probably going to send the head to endyn to get it fixed and p.p if they would ever return my emails.
By the way the r short block is possibly for sale, it has 5500 miles on it
[Modified by Tbone, 10:32 PM 6/27/2001]
Old Jun 27, 2001 | 10:42 PM
raene's Avatar
Default Re: Your wish list! (Tbone)
LOL, no doubt, that's funny... probably why only like 6 people replied; eveyone else is scared of getting jacked... ******* thieves.
I forgot to mention, I have KVR slotted rotors (front), KVR carbon fiber brake pads (front) and ATE Super Blue brake fluid as well .
Old Jun 28, 2001 | 04:49 AM
eg6ajk's Avatar
its true but what if they steal your car and expect all this ****, and all they see is a DX 1.5l motor with polished Reactive cone, some chopped springs...
then they get on the board and start bitch that everyone is a liar .....and how your setup is ****...
Old Jun 29, 2001 | 12:41 PM
EDwEFprts's Avatar
what i've got:
JDM b16a; LSD; Y1 tranny; PLACERACING mounts and intake with K&N filter; JUN flywheel; ACT clutch; AEROSPEED coilovers; JDM front end; stripped interior with no radio; DC 4-2-1 header with racing cat and custom exhaust coming soon.
what i want:
SPOON wires; battery relocator kit; TOKICO 5-way adjustables (ZEAL suspension, but that's too much $); HX wheels painted bronze; MUGEN strut tower bars (if they'll fit); TAKATA 4-point harnesses; new championship white paint job; CF MUGEN/SPOON style mirrors; maybe a role cage; go turbo.
[Modified by JDMb16aEF9, 10:56 PM 6/29/2001]
Old Jun 29, 2001 | 06:34 PM
Trinity's Avatar
Default Re: Your wish list! (JDMb16aEF9)
well i blew my engine up so i dont' have much now! i do have konig rated r's in white (15's) and some springs and yadda yadda.
now onto what i want: ok SIR front end and gauge cluster with the SIR engine to match. New interior with recaro racing seats. New system (since my **** got stolen), some velox guages( they may look ricey but i guess i have to find out, i really like the damn things), a turbo for my bueatiful JDM engine , all internals built to hell and back so it can handle high boost( just for running times, not every day boost) . I want a tein suspension set-up ( why because i think they are the best) , AND my last goal is to have Volk te-36's on my car in white. yeah that is about it if i think of anything else i will let you peeps know!
hyper em1
Northeast (Sales)
Feb 13, 2007 12:16 PM
DISMANTLERGSR
Jan 12, 2004 10:49 PM
vactor
Jun 21, 2003 07:47 AM
NeXtLeVeL_TyPe_R
Nov 26, 2002 04:09 AM
