CRX si cam in turbo D15B7? Will this work?
Old Apr 16, 2003 | 07:06 AM
BoostedD15B7's Avatar
Default CRX si cam in turbo D15B7? Will this work?
Im running a Drag gen 3 kit on my D15B7. The only problem im having is the power is dying off after 5,500 rpm because of the dx cam. Can't is swap it for the CRX si cam to raise the powerband a little more? Im willing to sacrifice a little low end torque for some more top end. I want something that will pull till about 7,000 but idle like stock. Is the si cam the best choice for this?
Old Apr 16, 2003 | 07:56 AM
zcivicz's Avatar
Default Re: CRX si cam in turbo D15B7? Will this work? (BoostedD15B7)
yep!
Old Apr 16, 2003 | 08:39 AM
Default Re: CRX si cam in turbo D15B7? Will this work? (zcivicz)
Do you happen to know what the power band is on that cam? Also, would i use the stock clearence, or the clearence for the CRX si?
Old Apr 28, 2003 | 10:29 PM
89dxhunchback's Avatar
I didn't feel like dealing with valve springs and lash adjustments etc. so I just swapped to a Si/A6 head just for the cam.
luckecharm2004
Sep 30, 2004 10:32 AM
tgreaves
Nov 14, 2003 10:18 AM
auto-x
Aug 14, 2003 06:02 AM
Red_Si
May 29, 2003 08:20 AM
B_1_8_hatch
29
Aug 7, 2002 04:50 AM
