Anybody with a single cam turbo ef?
Old Apr 16, 2003 | 06:13 AM
97itr86's Avatar
Default Anybody with a single cam turbo ef?
I am looking for single cam turbo track times and setups. I am still trying to figure out my new project so, I need ideas.
Old Apr 16, 2003 | 06:21 AM
USDM 4G VTEC's Avatar
Default Re: Anybody with a single cam turbo ef? (97itr86)
darth boost herre has a 5G SOHC VTEC with turbo @ 7 psi....
its a quick ****.....
i dont know about 1/4 times but i know hes into mid/high 14's
Old Apr 16, 2003 | 06:45 AM
NipponRacing's Avatar
Default Re: Anybody with a single cam turbo ef? (USDM 4G VTEC)
that's not very fast for sohc turbo...
should get you into low 14's maybe high 13's.
I run 14.8 with i/h/e on d16y8 so a turbo should take off almost a second.
Old Apr 16, 2003 | 09:01 AM
ViperRedCRX's Avatar
Default Re: Anybody with a single cam turbo ef? (NipponRacing)
i had a 91 dx with a d16z and a ghetto turbo it ran pretty good to be on bs dtreet tires and a stock 110k mile clutch...13.6@106
Old Apr 16, 2003 | 09:16 AM
1.8Tities's Avatar
I'm in a process of doing mine.
Current N/A set up:
AEM CAI
Stage1 Crane Cam
D16y8 intake manifold
91 Teg LS TB portmatched
Airmass header
B&M FPR
etc..
Here is my home-made turbo set-up, and here's what I collected so far:
Garret t25 turbo
STD ex manifold
2nd gen eclipse BOV free( looking for a 1st gen BOV though)
custom adapter plate
t25 dp flange
SMC+ fuel management
1st gen eclipse SMIC
autometer a/f and boost gauge
Still looking
450cc DSM injectors
Charge pipings
Return/feed lines+fittings
Only three more and I'm all set!
Old Apr 16, 2003 | 10:08 AM
mikikanazawa's Avatar
I had a 1991 Civic EX sedan with auto trans and a GReddy kit.
It ran 14.39 at LACR consistently, but I had to screw with it to get those times.
I would say go with a DRAG kit. My friend had a '90 CRX Si and with the DRAG kit at 9 PSI it was making 190 @ the wheel. Never took it to the strip so can't give you an ET though.
Old Apr 16, 2003 | 12:32 PM
13HYBRID20's Avatar
Default Re: Anybody with a single cam turbo ef? (mikikanazawa)
or you could get a b16 with a turbo and run 12's
Old Apr 16, 2003 | 12:40 PM
drjondurst's Avatar
Default Re: Anybody with a single cam turbo ef? (13HYBRID20)
or you can spend less money and run 13s
Old Apr 17, 2003 | 05:46 AM
trbochgd_civic_grl's Avatar
Go to your nearest Dodge Chrysler or Mits dealership and order oil return line for a stock turbo car. Thats what we did. The one I have is flexible also.
Old Apr 17, 2003 | 05:48 AM
1.8Tities's Avatar
Default Re: Anybody with a single cam turbo ef? (trbochgd_civic_grl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trbochgd_civic_grl &raquo;</TD></TR><TR><TD CLASS="quote">Go to your nearest Dodge Chrysler or Mits dealership and order oil return line for a stock turbo car. Thats what we did. The one I have is flexible also. </TD></TR></TABLE>They will charge you a grip though.
Joey B 18C
17
Jul 11, 2004 10:22 AM
lmiguelvv
Apr 19, 2004 08:11 AM
B20 BEAST
Apr 12, 2003 11:50 AM
Desperado
Mar 26, 2003 06:01 PM
IZZY_sohc_00
Oct 11, 2002 09:42 AM
