How to prep OEM skirt for painting ?
Old Apr 16, 2003 | 12:15 AM
dashark's Avatar
Default How to prep OEM skirt for painting ?
Just bought a OEM skirt kit for my 99 GS, but I need to paint it a different color. I am going to get it professionnally done, but wanted to sand it and prime it so I can save a few $$. How do I do it ????
Old Apr 16, 2003 | 12:18 AM
integrasi's Avatar
Default Re: How to prep OEM skirt for painting ? (dashark)
u don't need to prime, just sand it really really well, especially side skirt.
Old Apr 16, 2003 | 12:45 AM
dashark's Avatar
Default Re: How to prep OEM skirt for painting ? (integrasi)
what grain sand paper shoud I start with and finish ?
Old Apr 16, 2003 | 07:43 AM
JDMDAINTEG's Avatar
Go to a auto paint store and get red ScotchBrite Pads, there real cheap.
Old Apr 16, 2003 | 08:15 AM
StyleTEG's Avatar
I would prime it, thats an area that is going to get a lot of rocks thrown at it and tons of feet scrapping against it. Any thing you can do to make the paint more solid and flake free, the better.
Old Apr 16, 2003 | 11:27 AM
E-Rok's Avatar
EPIC TUNING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi &raquo;</TD></TR><TR><TD CLASS="quote">u don't need to prime, just sand it really really well, especially side skirt. </TD></TR></TABLE>
lol why would you not need to prime?
Old Apr 16, 2003 | 06:51 PM
dashark's Avatar
Default Re: How to prep OEM skirt for painting ? (rewsnaeht)
Any other tips....
Old Apr 16, 2003 | 07:21 PM
zigs's Avatar
For best look you can use either 320 wet or scothbrite pads work as well clean it with some wax and grease remover before you start sanding then sand it then wax and grease again then I would prime it and sand the primer with 600 grit and then if you didnt sand through the primer anywhere you can just wax and grease it again and then basecoat and then the clear if you go thorugh I would prob seal it then proceed. HTH
Old Apr 16, 2003 | 09:35 PM
pr0jektdc2's Avatar
dont forget flex additive...
Old Apr 16, 2003 | 09:40 PM
romeo619romeo's Avatar
Default Re: (pr0jektdc2)
yup you need to mix something in the paint since its poly.
Old Apr 16, 2003 | 09:47 PM
pr0jektdc2's Avatar
Default Re: (romeo619romeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeo619romeo &raquo;</TD></TR><TR><TD CLASS="quote">yup you need to mix something in the paint since its poly.</TD></TR></TABLE>
ABS plastic i believe but correct me if im wrong...
Old Apr 19, 2003 | 10:58 PM
integrasi's Avatar
cuz, it ain't going to rust. the whole point of prime is to prevent from rust.
Old Apr 21, 2003 | 07:56 AM
E-Rok's Avatar
EPIC TUNING
paint sticks better to a primered surface.
Old Apr 21, 2003 | 08:02 AM
IntEGNYC's Avatar
Is that why the walls in my house havent rusted?... heh
I think youre referring to rustoleum.
Priming makes the paint adhere to the surface.
Be sure to mix in flex additive to prevent the paint from cracking.
Old Apr 21, 2003 | 08:11 AM
gokooljapan's Avatar
NOOOOOOOO, you have got it all wrong. you DO NOT need SAND any ABS plastics unless you are repairing it. If you do sand it, it will leave a wierd look when painted (kinda rough look and sometimes you can't make the plastic sit correctly.
This is ALL you have to do:
1. wash part with dish soap (stuff that removes grease) and let dry
2. use SEM plastic prep, you may also use SEM vinyl prep. this makes the surface soft and adhere to paint
3. use "bulldog" paint adhesive or SEM Sand Free.
4. when you paint it using a spray gun, just dont put too much hardener in the clearcoat. (you do not need any type of flex paint or special thing)
5. if you spray paint it, then just follow the directions on the can. &lt; this will not give you the best finish.
SEM is a brand of paint supplies. If you are still confused, i would suggest having a pro do it if you want a professional finish.
hope this helps.
Old Apr 21, 2003 | 08:12 AM
Default Re: How to prep OEM skirt for painting ? (gokooljapan)
since you are going to get is professionally done, just don't do anything to it because you will just make it worse for them if you do something wrong. you will end up paying more. IMO.
tweensquirt
Paint and Body
Mar 19, 2012 06:20 PM
L.David
Honda S2000
Feb 23, 2008 04:31 AM
civicandy
Paint and Body
May 12, 2007 06:01 PM
mrDFWmechanic
Jun 28, 2005 12:00 PM
atlprelude01
May 15, 2003 06:36 AM
