Anyone with B18C5 torque specs!?!?
If you don't have an Inch/lb torque wrench, don't try to torque the squirters. You will strip and break them.
I'll help you by posting this.
http://www.tleone.com/hondatec...5.zip
I was going to make one for the block too, but never got around to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThunderLips »</TD></TR><TR><TD CLASS="quote">The ITR expo was off the hook...
Helms ownz jOO!</TD></TR></TABLE>
thanks for the help Michael
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">If you don't have an Inch/lb torque wrench, don't try to torque the squirters. You will strip and break them.
Thanks Tony. Do you have the block specs by chance, and just give me the rod caps, and mains so I can keep myself busy...lol
TIA
TIA
Oil squirters : 12 ft/lbs
Rods : Honda says to use the stretch method on the R, but I used the GSR spec which is 33 ft/lbs
The Mains are 56 ft/lbs OFF of the girdle and 49 ft/lbs ON the girdle
Dangger
Sep 22, 2006 05:41 PM
