- Those with CAM GEARS
Old Apr 15, 2003 | 10:13 PM
The-LS's Avatar
Default - Those with CAM GEARS
I just had some Skunk2 cam gears installed and now I hear some whining noise. I'm pretty sure its related to 1 belt or another. I'm just curious does anyone else hear any belt noises? Or did my mechanic possibly tighten my other drive belts too much? Its not really loud at all, it sounds like a small electric motor type noise that varies with the RPMS.
Old Apr 16, 2003 | 12:44 AM
PYITR821's Avatar
Default Re: - Those with CAM GEARS (Black-LS)
Are your cam gears covered with the oem plastic cover? If your cam gears aren't covered up then they will make a little extra noise. I noticed that when I had cam gears with a cut valve cover that it was a little louder.
Old Apr 16, 2003 | 05:36 AM
IN VTEC's Avatar
Belt tension's probably a little tighter than normal.
Old Apr 16, 2003 | 12:47 PM
The-LS's Avatar
Default Re: - Those with CAM GEARS (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Belt tension's probably a little tighter than normal.</TD></TR></TABLE>
You mean tension on my other drive belts right? As for the cam gears, the valve cover is UNcut and the timing belt cover is still on. So its just like stock right now with the exception that the cam gears are inside.
Old Apr 16, 2003 | 01:26 PM
MikeSarr_GSR's Avatar
your timing belt is too tight, sounds like SC! Fun
SNAP
Old Apr 16, 2003 | 06:04 PM
The-LS's Avatar
Default Re: - Those with CAM GEARS (MikeSarr_GSR)
Would the design of the cam gears alone make noise just spinning?? Or is my timing belt most likely too tight? Is it neccessary to loosen the timing belt tensioner to install the cam gears?
Old Apr 16, 2003 | 06:09 PM
B00ST2nR's Avatar
I've never heard my Cam Gears making that sound...
Does it make that sound during idle?
Old Apr 16, 2003 | 06:16 PM
mr.beeks's Avatar
Default Re: - Those with CAM GEARS (Skunk2nR)
I have skunk gears
and cut valve cover plus plastic cover removed
and no noise there
just like everybody says to tight
or your tension pulley is about to go away
check it asap before you break the timming belt
The-LS's Avatar
at idle there seems to be no sound. But when you rev the car like the other guy said, it kinda sounds like a supercharger whining... but really low volume. Its not REAL loud or anything, it just that its a NEW sound for me and I'm just checking if its considered normal or should I worry about something.
Old Apr 16, 2003 | 08:23 PM
your timing belt is tight.
Old Apr 17, 2003 | 11:51 AM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">your timing belt is tight.</TD></TR></TABLE>
Just readjusted the timing belt tension... well actually loosened it. The sound is gone, thanks guys.
Old Apr 17, 2003 | 12:07 PM
illi Adik's Avatar
That could have been trouble.
Old Apr 17, 2003 | 01:34 PM
mr.beeks's Avatar
Default Re: - Those with CAM GEARS (Jackson4Door)
lucky
EKJOE
May 16, 2009 09:14 AM
92integracer
Jan 17, 2007 01:51 AM
doublejz
Nov 12, 2005 03:06 PM
Asahi
Dec 9, 2003 12:15 AM
