ls crank for ls/vtec
Old Apr 15, 2003 | 10:00 PM
EvilIntegrationLS's Avatar
Default ls crank for ls/vtec
question....i plan on getting my ls built into an ls/vtec, and was just wondering if the stock ls crankshaft can hold 8k rpm without any problems. or will the crank have to be micropolished and blah blah??? thanks
Old Apr 15, 2003 | 10:36 PM
Hate's Avatar
Default Re: ls crank for ls/vtec (EvilIntegrationLS)
your LS engine doesnt make power past 7800 rpm. LS/Vtec is a horrible idea, if it wasnt honda would have done it 10 years ago. the LS block isnt a high reving block, the Vtec head is a high reving head. you could bore out the block and sleeve it with ITR internals, but thatll hold up for about a year. answer: no
Old Apr 15, 2003 | 10:57 PM
integracion's Avatar
Default Re: ls crank for ls/vtec (Hate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hate &raquo;</TD></TR><TR><TD CLASS="quote">your LS engine doesnt make power past 7800 rpm. LS/Vtec is a horrible idea, if it wasnt honda would have done it 10 years ago. the LS block isnt a high reving block, the Vtec head is a high reving head. you could bore out the block and sleeve it with ITR internals, but thatll hold up for about a year. answer: no</TD></TR></TABLE>
lol, man you need to read more before you answere this type of questions.
Old Apr 15, 2003 | 11:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilIntegrationLS &raquo;</TD></TR><TR><TD CLASS="quote">question....i plan on getting my ls built into an ls/vtec, and was just wondering if the stock ls crankshaft can hold 8k rpm without any problems. or will the crank have to be micropolished and blah blah??? thanks</TD></TR></TABLE>
do a search, you can find alot of info on how to build a reliable ls/vtec
Old Apr 15, 2003 | 11:10 PM
Default Re: ls crank for ls/vtec (integracion)
i think you're missing the question, i asked about the crank holding up past 8k rpm, not if the block is high reving. its only revved that high because it is a non vtec motor with low compression, so yea, naturally it wont rev that high in the first place. but i'm asking about the crank.
Old Apr 15, 2003 | 11:13 PM
Hate's Avatar
i need to read more? ok let me explain this better. the b18a/b bottom end cant handle high revs. thats why an LS/VTEC conversion isnt an efficient setup. the rod/stroke ratio limits how high a motor can rev. follow. and the b18a/b doesnt have a high revving r/s ratio. on top of that the LS doesnt ahev oil squirters capable of providing enough oil at higher rpms. oh and a typo from before the redline is 6800...not 7800
Old Apr 15, 2003 | 11:15 PM
Default Re: (Hate)
haha, yea i was about to correct you on that earlier...6800
Old Apr 15, 2003 | 11:16 PM
Hate's Avatar
dude...LS/VTEC = bad idea. your still up for spending as much money as it would take to swap a decent motor in? the answer is yes for a short amount of time it will hold up
Old Apr 16, 2003 | 03:33 AM
JeremyL's Avatar
Default Re: (Hate)
for the amount of money it would take to build a reliable LS/VTEC you could swap in a C1 long block and ecu
Old Apr 16, 2003 | 06:31 AM
avividmemory's Avatar
Default Re: (Hate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hate &raquo;</TD></TR><TR><TD CLASS="quote">dude...LS/VTEC = bad idea. your still up for spending as much money as it would take to swap a decent motor in? the answer is yes for a short amount of time it will hold up
STFU...don't throw words around when you have only heard them from other people, thats whats called a rumor...if you don't know the real facts about it, don't spread the rumors around...
and a well-built (keyword:well-built) ls/vtec setup is just as reliable as any other...trust me, I've done it...
Old Apr 16, 2003 | 07:54 AM
jdmskin's Avatar
Default Re: (SpoolinLS)
do a search!
i dont believe the crank is different???????
could be though
Old Apr 16, 2003 | 08:03 AM
13HYBRID20's Avatar
Default Re: (jdmskin)
I have a LS VTEC and I sift at 8500 just put on a type r oil and water pump. That oil squirter **** is for **** I know many people who put ctr slugs in their gsr and do you think they shift at 6800 shut up you don't even have a LS block you never drove a LS block so why give some stupid IMO bull ****.
Old Apr 16, 2003 | 08:34 AM
Hate's Avatar
ive never driven an LS block? i have a ****** LS. Ive also driven a LS/Vtec with itr internals. The LS/Vtec motor lasted for about a year....end yourself.
Old Apr 16, 2003 | 09:40 AM
Default Re: (Hate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hate &raquo;</TD></TR><TR><TD CLASS="quote">ive never driven an LS block? i have a ****** LS. Ive also driven a LS/Vtec with itr internals. The LS/Vtec motor lasted for about a year....end yourself.</TD></TR></TABLE>
so you built the ls/vtec? maybe thats part of the reason it didnt last...
Old Apr 16, 2003 | 09:52 AM
LSRydeR's Avatar
All you guys have to remember is when that issue of IMPORT RACER came out and on the front page had a integra LS/VTEC with TURBO pushing 500hp!... that is reliable... enough said
Old Apr 16, 2003 | 09:56 AM
13HYBRID20's Avatar
Default Re: (LSRydeR)
HA HA
Old Apr 16, 2003 | 10:30 AM
JeremyL's Avatar
Default Re: (13HYBRID20)
hmmm a pissing contets...ill stay out
Old Apr 17, 2003 | 08:40 AM
Default Re: (JeremyL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeremyL &raquo;</TD></TR><TR><TD CLASS="quote">hmmm a pissing contets...ill stay out</TD></TR></TABLE>
hahaha, one question is all it takes
Old Apr 17, 2003 | 09:09 AM
JeremyL's Avatar
Default Re: (EvilIntegrationLS)
i dont see why an LS crank powered engine wouldnt be able to rev as high as long as the bearings can take it and its all put together properly
Old Apr 17, 2003 | 09:22 AM
SlowPoke's Avatar
New User
Default Re: (Hate)
Jeez you make it sound like LS/Vtec is the end of the world. Yes there are other motors you can mod for that much money, but what if the person doesnt care and is set on building an ls/vtec? It can be as reliable as any. For the oil squiters, screw it, just get forged pistons. For revving to 8grand, Crower 404 cams make power up to 8000, so there are cams that require ls motors to rev to 8. As for your friends motor blowing up, I'd say poorly built, or poorly driven. If the bottom end is built correctly withing spec, new bearings, and fully balanced bottom end, it should last also with the assumption you don't drive like ****. By the way, you can have a nice stock type R motor and still kill it in a year if you drive like ****.
Old Apr 17, 2003 | 10:43 AM
JeremyL's Avatar
Default Re: (SlowPoke)
tuning and grade of gas used is probably an even bigger factor in longevity than the quality of the build, of course there is no better tuning factor than a reasonable and compotent driver
Old Apr 17, 2003 | 11:02 AM
gertrider's Avatar
i disagree. I know somebody with an ls/vtec. good power and very fast! and its lasted way longer than a year Its a good combo, i say go for it!
Old Apr 17, 2003 | 11:45 AM
hatch_attack's Avatar
Default Re: ls crank for ls/vtec (gertrider)
what if you were to use a b17 crank or a b18c crank?...wouldnt that make your r/s ratio much better therefore allowing it to rev higher safer?
Old Apr 17, 2003 | 12:56 PM
J337_UNIT's Avatar
Default Re: ls crank for ls/vtec (theswarm)
get a stroker kit
Old Apr 17, 2003 | 05:22 PM
JeremyL's Avatar
Default Re: ls crank for ls/vtec (J337_UNIT)
the best way to go high revving and still have good torque would be to use a B16 block and bore it 84mm
