How do I adjust Timing on an Unorthodox racing crank pulley?
Old Apr 15, 2003 | 06:34 PM
wantmorepower's Avatar
New User
Default How do I adjust Timing on an Unorthodox racing crank pulley?
Does anyone know how to adjust timing on a Unorthodox racing crank race pulley (B18c5)? There is only one mark on it. Thanks
(I wish I can trade it for an http://www.inlinefour.com/infourn1encr.html pulley)
Old Apr 15, 2003 | 06:43 PM
d15nonvtec's Avatar
Default Re: How do I adjust Timing on an Unorthodox racing crank pulley? (wantmorepower)
i would get rid of the aftermarket crank pulley. they always do more damage then good. i would rather not gain the 2-5 hp, then replace my motor. seriously
Old Apr 15, 2003 | 07:04 PM
NonovUrbizniz's Avatar
Loved
Default Re: How do I adjust Timing on an Unorthodox racing crank pulley? (d15nonvtec)
you adjust the timing on the cams not the crank... you always want the crank set at the tdc mark and nothing else... If you want to mess with timing do it via the cams and dist.
Old Apr 15, 2003 | 07:06 PM
New User
Default Re: How do I adjust Timing on an Unorthodox racing crank pulley? (NonovUrbizniz)
I will be using the distributor for timing adjustments but want I want to know is
Since there is only one mark on the pulley then what do I do?
Old Apr 15, 2003 | 07:17 PM
Loved
did you get my im
if not... there should only be 1 mark there should be a corresponding mark on the block check your manual... if you don't have one ask someone to post a pic of that page...
red civic standard
Sep 27, 2004 09:02 PM
iperez
Jun 24, 2004 06:58 AM
Nextelbuddy
Mar 29, 2004 11:43 AM
89JDMcrx
Sep 25, 2002 05:22 PM
Nick248
Sep 9, 2002 09:59 PM
